Fedora 25 Help - Start Channels-DVR automatically after reboot
I have channels-dvr installed on Fedora 25 Workstation on an external usb drive. Media is located on it also. Works great except it doesn’t seem to autostart on reboot.
I’m a dabbler with linux so not sure how to get this to start. Plex starts and I can get full applications to start with the tweak tool.
Thanks for any help!
Hmm, I think you would need to edit the DVR systemd configuration to add a dependency on local-fs.target
Edit /etc/systemd/system/channels-dvr.service (as root), find these two lines:
Wants=network-online.target
After=network-online.target
and change them to:
Wants=network-online.target local-fs.target
After=network-online.target local-fs.target
Then reboot and see if it works. If it does, let me know and I will change the installer to use that by default.
Tried it…didn’t work. I may just try Unbuntu as I’ve worked with it more.
