Freenas plugin will not start
I just subscribed to the dvr and installed the freenas plugin and the service will not start.
What version of FreeNAS?
Do you see an error message of some sort? Can you screenshot?
no error message i just click to turn it on and it doesn’t start
root@freenas /mnt]# ls
data md_size
[root@freenas /mnt]# cd data
[root@freenas /mnt/data]# ls
jails mickey_tm sktrstang_tm windows_data
[root@freenas /mnt/data]# cd kails
bash: cd: kails: No such file or directory
[root@freenas /mnt/data]# cd jails
[root@freenas /mnt/data/jails]# ls
.customplugin_1.meta .warden-template-pluginjail
.plugins customplugin_1
.warden-files-cache warden.log
[root@freenas /mnt/data/jails]# cd customp*
[root@freenas /mnt/data/jails/customplugin_1]# ls
.cshrc dev rescue
.plugins etc root
.profile lib sbin
COPYRIGHT libexec sys
bin media tmp
boot mnt usr
channels-dvr.log proc var
[root@freenas /mnt/data/jails/customplugin_1]# cat channels-dvr.log
exec: /usr/pbi/channels-dvr-amd64/channels-dvr/latest/channels-dvr: not found
[root@freenas /mnt/data/jails/customplugin_1]# cd usr
[root@freenas /mnt/data/jails/customplugin_1/usr]# ls
bin include lib32 libexec obj sbin src
games lib libdata local pbi share
[root@freenas /mnt/data/jails/customplugin_1/usr]# cd pbi
[root@freenas /mnt/data/jails/customplugin_1/usr/pbi]# ls
channels-dvr-amd64
do i need to make a sym link or edit some file to point it to the correct directory ?
It looks like the installation might have failed. What version of FreeNAS are you using?
Run “ls -alh /mnt/data/jails/customplugin_1/usr/pbi/channels-dvr-amd64/channels-dvr”
Also run:
cat /mnt/data/jails/customplugin_1/usr/pbi/channels-dvr-amd64/setup.log
i did find that the setup.sh was zero should i do the wget comand i saw from a earlier post?
Yea, what does it say when you do:
cd /tmp
wget -q -O setup.sh https://getchannels.com/dvr/setup.sh
Please tell me the version of FreeNAS that is running…
-rw-rw-r-- 1 root wheel 2422 Feb 28 14:26 setup.sh
drwxrwxrwt 2 root wheel 0 Mar 1 16:21 vi.recover
[root@freenas /tmp]# unamme -a
bash: unamme: command not found
[root@freenas /tmp]# uname -a
FreeBSD freenas.mickey.local 10.3-STABLE FreeBSD 10.3-STABLE #0 r295946+1805185(
9.10.2-STABLE): Wed Jan 11 17:12:42 UTC 2017 root@gauntlet:/freenas-9.10-rel
eng/_BE/objs/freenas-9.10-releng/_BE/os/sys/FreeNAS.amd64 amd64
Okay, it’s been working fine for other users on 9.10.
Also it looks like the wget worked when you did it in /tmp?
Did you try removing the plugin/jail and reinstalling it? Could be a weird failure downloading the setup script last time.
yes i have reinstalled the plugin twice same error
should i just run the setup.sh to install the rest of it?
as there is no setup.log file
I would like to see the output of this command:
[root@freenas /mnt/data/jails/customplugin_1/usr/pbi]# ls -alh /mnt/data/jails/c
total 6541
drwxr-xr-x 3 501 staff 11B Mar 1 16:49 .
drwxr-xr-x 3 root wheel 3B Mar 1 16:47 …
-rw------- 1 root staff 181B Mar 1 16:49 .oauth
-rwxr-xr-x 1 501 staff 456B Dec 5 18:34 control
-rw-r–r-- 1 root staff 39B Mar 1 16:49 control.conf
-rwxr-xr-x 1 501 staff 5.9M Dec 6 18:20 control.fcgi
-rw-r–r-- 1 501 staff 779B Dec 3 12:13 default.png
drwxr-xr-x 3 501 staff 3B Dec 2 17:58 etc
-rw-r–r-- 1 501 staff 15B Dec 2 15:22 freenas
-rw-r–r-- 1 root staff 2.4K Feb 28 14:26 setup.sh
-rwxr-xr-x 1 501 staff 222B Dec 2 17:57 tweak-rcconf
i did the wget earlier in this directory as the setup.sh was zero
I see. This means the wget is broken when run from inside the jail. If that’s the case, it’s going to cause other problems later, so running the setup.sh by hand is not recommended.
Can you go the customplugin_1 jail in the FreeNAS interface and connect a console into it, then try running the same wget command to see what it says. You can remove the -q to make sure it prints out any errors.
when i try that it will not ping out or anything
root@customplugin_1:/usr/pbi/channels-dvr-amd64 # wget -O setup.sh https://getch
–2017-03-01 18:05:43-- https://getchannels.com/dvr/setup.sh
Resolving getchannels.com (getchannels.com)…
The jail is supposed to be created with its own IP address…
Check ifconfig -a in the jail? I’m not really sure why it would be missing network connectivity. I only have very basic experience with FreeNAS, and when I set it up to test jails were created with separate IPs automatically.
root@customplugin_1:/ # ifconfig -a
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
inet 127.0.0.1 netmask 0xff000000
nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:ff:b0:00:05:0b
inet 192.168.150.71 netmask 0xffffff00 broadcast 192.168.150.255
nd6 options=9<PERFORMNUD,IFDISABLED>
media: Ethernet 10Gbase-T (10Gbase-T )
status: active
