Frndly TV for Channels
New Guy here
I have everything set up and working fine with Frndly TV, Pluto, YouTube TV. Love the integration.
However, I've noticed with Frndly TV, everything seems to work and then about 0300 (3 a.m.) Everything on Frndly stops recording. I did have remote channels set up but I removed that from my Android, and deleted the port forward in my router for it as a precaution.
I set up Frndly TV per the forum instruction and have latest docker and Channels. Is there something else I should be doing? Added firewall exception even though, 3 weeks ago when I added Frndly TV, I didn't need one. It all worked fine until this weekend and now it seems as if this is a nightly issue.
Ideas? Can you point me to a post that is similar that I haven't found with some corrective steps, please?
Thanks in advance
I replied in your other thread too…
I found the status website @Absenm posted a couple days ago helpful
What are you even asking me? The issue I raise is that the author of frndlytv for channels says this is where to go for support. Take that up with Mr Matt
You said your no longer using channels.
Why are you still here?
I also have chosen not to support you either on here or github.
So save your time.
The docker is working great here for me.
The Creation of the project has allowed me to have a more accessible version of FRNDLY TV.
I find it easier to use Channels to navigate programming over the default APPs due to my use of Voice over Screen reader on my phone and apple tv.
The channels app along with the different docker projects allow for me to independently access different services.
Thanks for the great work!!!!
Getting random 404 errors on in-progress recordings - anyone else?
2022/07/02 12:23:06.300206 [ERR] Error during stream M3U-FrndlyTV ch9013 GAC Family: Failed to download file: https://sr-live2-frndly.akamaized.net/v1/manifest/segment/840a24ccd7c75076211d060179b3ad0c64fdc6ca/live_v2_nr_new/d8c3a74b-fd91-429c-b447-e2bbe7d7effb/0/351377: 404 Not Found
2022/07/02 12:23:06.388728 [MTS] Statistics for "Movies/The Christmas Star (2021) 2022-07-02-1159.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=8611.512000
2022/07/02 12:23:06.530567 [TNR] Closed connection to M3U-FrndlyTV for ch9013 GAC Family
2022/07/02 12:23:06.531866 [DVR] Job 1656777590-98 The Christmas Star (2021) ended prematurely: 1h37m53.468136s
2022/07/02 12:23:06.590888 [DVR] Starting job 1656777590-98 The Christmas Star (2021) on ch=[9013]
2022/07/02 12:23:06.590917 [DVR] Waiting 1h36m43.409084s until next job 1656784790-98 Jingle Bell Princess (2021)
2022/07/02 12:23:06.997539 [TNR] Opened connection to M3U-FrndlyTV for ch9013 GAC Family
2022/07/02 12:23:06.997766 [DVR] Recording for job 1656777590-98 from M3U-FrndlyTV ch9013 into "Movies/The Christmas Star (2021) 2022-07-02-1159.mpg" for 1h37m53.409049s
Ok I can confirm that is happening to me too. I set 3 shows on 3 different Frndly channels at different times to record this afternoon. Two were interrupted. I’m on latest docker. KEEP_ALIVE=5. I’ll check the docker logs when I get home and see if there is anything showing there.
Got a couple exactly like that last night on 2 different recordings from MeTV.
First time I've seen that error on a frndlyTV channel.
In my case it had just logged in to make the two back-back recordings and no logins after that until this mornings guide update. I have KEEP_ALIVE disabled.
Channels & Docker logs when the two recordings were interrupted
2022-07-02T01:58:00.515743946Z 401
2022-07-02T01:58:00.516446020Z Unauthorized access
2022-07-02T01:58:00.516600150Z logging in....
2022-07-02T01:58:01.867421630Z Logged in!
2022-07-02T01:58:02.058407838Z 192.168.1.3 - - [02/Jul/2022 01:58:02] "GET /play/me_tv.m3u8 HTTP/1.1" 302 -
2022/07/01 18:58:02.995696 [TNR] Opened connection to M3U-frndlyTV for ch9001 MeTV
2022/07/01 19:00:14.216822 [ERR] Error during stream M3U-frndlyTV ch9001 MeTV: Failed to download file: https://sr-live2-frndly.akamaized.net/v1/manifest/segment/...: 404 Not Found
2022/07/01 19:00:14.574147 [TNR] Closed connection to M3U-frndlyTV for ch9001 MeTV
2022-07-02T02:00:15.218547665Z 192.168.1.3 - - [02/Jul/2022 02:00:15] "GET /play/me_tv.m3u8 HTTP/1.1" 302 -
2022/07/01 19:00:15.881520 [TNR] Opened connection to M3U-frndlyTV for ch9001 MeTV
2022/07/01 19:28:00.085408 [TNR] Sharing existing connection to M3U-frndlyTV for ch9001 MeTV (clients=2, len=0)
2022/07/01 20:00:15.509024 [ERR] Error during stream M3U-frndlyTV ch9001 MeTV: Failed to download file: https://sr-live2-frndly.akamaized.net/v1/manifest/segment/...: 404 Not Found
2022/07/01 20:00:16.447343 [TNR] Closed connection to M3U-frndlyTV for ch9001 MeTV
2022-07-02T03:00:17.317486658Z 192.168.1.3 - - [02/Jul/2022 03:00:17] "GET /play/me_tv.m3u8 HTTP/1.1" 302 -
2022/07/01 20:00:18.115089 [TNR] Opened connection to M3U-frndlyTV for ch9001 MeTV
I’m trying out a few more recordings. I lost my docker logs. When I tried looking at the Frndly-for-channels logs it ended up getting messed up so bad that it completely shut down docker all together. I had to reboot my Synology and remove the container and pull it again to get it going again. I’m not sure what happened there seeing as my xTeVe docker also went completely nuts so those issues are probably just me issues.
So anyway, I need to start with a new data set of recording. I’ll try to get some more data and logs this evening. I am currently not experiencing any issues with live broadcast.
Hi guys,
The ad insertion on FRNDLY is braking your recordings.
If you watch carefully on say Emergency on FETV, it will play until about 18 past the hour.
The system will try to push ad insertion that isn't in place.
The problem will cause issues on Stremium and on the app itself.
Well if it really is a momentary blip at ad insertion and the recording continues then the only issue is the loss of a split second of ad. I can live with that.
When the feed stops, i have to go back to the guide and launch the channel.
I'm hoping FETV and those folks at FRNDLY will correct the issue with insertion.
When the insertion works, it transitions nicely. FETV doesn't really allow for time to insert local ads.
My interruptions are occurring on multiple channels. I actually did not use FETV as one of my tests. I watched the recording at the time of the interruption and it was during a commercial break but I could not see the interruption.
Well my Docker logs are showing nothing at the time of interruption aside from the reconnection.
Channels Log
2022/07/02 20:59:30.000612 [DVR] Starting job 1656813570-ch5032 A Taste of Ireland on ch=[5032]
2022/07/02 20:59:30.000704 [DVR] Waiting 12h59m59.999300622s until next job 1656860370-35 Did I Mention Invention?
2022/07/02 20:59:31.270488 [TNR] Opened connection to M3U-Frndly2TV for ch5032 Recipe.TV
2022/07/02 20:59:31.270708 [DVR] Recording for job 1656813570-ch5032 from M3U-Frndly2TV ch5032 into "TV/A Taste of Ireland/A Taste of Ireland 2021-05-12 2022-07-02-2059.mpg" for 31m29.999264595s
2022/07/02 20:59:32.331194 [DVR] Refreshing metadata for A Taste of Ireland (19488988)
2022/07/02 20:59:33.579681 [IDX] Generating video index for job 1656813570-ch5032
2022/07/02 21:01:00.168341 [TNR] Closed connection to M3U-Frndly2TV for ch5010 Game Show Network
2022/07/02 21:01:00.428139 [MTS] Statistics for "TV/America Says/America Says S03E89 2019-11-21 The Teaching Crew vs Fun Teachers 2022-07-02-2029.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=1902.033333
2022/07/02 21:01:00.432353 [DVR] Finished job 1656811770-ch5010 America Says
2022/07/02 21:01:00.920219 [DVR] Waiting 12h58m29.079787648s until next job 1656860370-35 Did I Mention Invention?
2022/07/02 21:01:01.182362 [DVR] Processing file-5148: TV/America Says/America Says S03E89 2019-11-21 The Teaching Crew vs Fun Teachers 2022-07-02-2029.mpg
2022/07/02 21:01:02.200774 [DVR] Running commercial detection on file 5148 (TV/America Says/America Says S03E89 2019-11-21 The Teaching Crew vs Fun Teachers 2022-07-02-2029.mpg)
2022/07/02 21:05:40.739453 [DVR] Commercial detection for America Says S03E89 2019-11-21 The Teaching Crew vs Fun Teachers 2022-07-02-2029.mpg finished with 6 markers in 4m38.538945959s.
2022/07/02 21:22:01.585590 [ERR] Error during stream M3U-Frndly2TV ch5032 Recipe.TV: Failed to download file: https://sr-live2-frndly.akamaized.net/v1/manifest/segment/840a24ccd7c75076211d060179b3ad0c64fdc6ca/live_v2_nr_new/94c6cbab-e3e6-40ec-a973-fa7e0beba7a4/0/252186: 404 Not Found
2022/07/02 21:22:01.801648 [MTS] Statistics for "TV/A Taste of Ireland/A Taste of Ireland 2021-05-12 2022-07-02-2059.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=1351.366667
2022/07/02 21:22:01.943060 [TNR] Closed connection to M3U-Frndly2TV for ch5032 Recipe.TV
2022/07/02 21:22:01.943086 [DVR] Job 1656813570-ch5032 A Taste of Ireland ended prematurely: 8m58.056917699s
2022/07/02 21:22:02.352100 [DVR] Starting job 1656813570-ch5032 A Taste of Ireland on ch=[5032]
2022/07/02 21:22:02.352168 [DVR] Waiting 12h37m27.64783552s until next job 1656860370-35 Did I Mention Invention?
2022/07/02 21:22:03.439686 [TNR] Opened connection to M3U-Frndly2TV for ch5032 Recipe.TV
2022/07/02 21:22:03.439732 [DVR] Recording for job 1656813570-ch5032 from M3U-Frndly2TV ch5032 into "TV/A Taste of Ireland/A Taste of Ireland 2021-05-12 2022-07-02-2059.mpg" for 8m57.6478077s
2022/07/02 21:31:00.038316 [TNR] Closed connection to M3U-Frndly2TV for ch5032 Recipe.TV
2022/07/02 21:31:00.289983 [MTS] Statistics for "TV/A Taste of Ireland/A Taste of Ireland 2021-05-12 2022-07-02-2059.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=true saw_pmt=true highest_pts=1905.052189
2022/07/02 21:31:00.290090 [DVR] Finished job 1656813570-ch5032 A Taste of Ireland
2022/07/02 21:31:00.856975 [DVR] Waiting 12h28m29.143030427s until next job 1656860370-35 Did I Mention Invention?
2022/07/02 21:31:01.209774 [DVR] Processing file-5149: TV/A Taste of Ireland/A Taste of Ireland 2021-05-12 2022-07-02-2059.mpg
2022/07/02 21:31:02.520167 [IDX] Generating video index for file-5149: A Taste of Ireland 2021-05-12 2022-07-02-2059.mpg
2022/07/02 21:31:08.672776 [IDX] Finished video index generation for file-5149 in 6s
2022/07/02 21:31:09.090803 [DVR] Running commercial detection on file 5149 (TV/A Taste of Ireland/A Taste of Ireland 2021-05-12 2022-07-02-2059.mpg)
2022/07/02 21:36:19.349010 [DVR] Commercial detection for A Taste of Ireland 2021-05-12 2022-07-02-2059.mpg finished with 8 markers in 5m10.271048027s.
Docker Log
2022-07-03T02:22:02.806484476Z,stdout,"channel/live/recipe_tv > https://sr-live2-frndly.akamaized.net/v1/master/840a24ccd7c75076211d060179b3ad0c64fdc6ca/live_v2_nr_new/dbfd8439e2bd4a9b97b9fbc9a98bacc2/index.m3u8?ads.rating=tvg&ads.title=a%255Ftaste%255Fof%255Fireland&ads.contenttype=live&ads.app_store_url=https://play.google.com/store/apps/details?id=com.tvapp.frndlytv&ads.app_bundle=com.tvapp.frndlytv&ads.station=recipetv&ads.us_privacy=1YNY&ads.duration=1800000&ads.genre=food%252Ccooking%252Cinstruction&ads.did=d36cc1c5-945b-32fa-ae11-d2e87e215a3f&hdnts=st=1656814922~exp=1656836522~acl=!*/v1/master/840a24ccd7c75076211d060179b3ad0c64fdc6ca/live_v2_nr_new/dbfd8439e2bd4a9b97b9fbc9a98bacc2/*!/payload/yupptvott_43_1181269_SHIELD30X8X4X0_US_172.225.20.133, 65.30.226.226_frndlytv_1_channel_19_-1/*~data=yupptvott_43_1181269_SHIELD30X8X4X0_US_172.225.20.133, 65.30.226.226_frndlytv_1_channel_19_-1~hmac=243c0624f820ce4cbb6c0e060f2a92d204af57c291fb541739ead6cd16d58095
2022-07-03T02:20:42.236785513Z,stderr,127.0.0.1 - - [03/Jul/2022 02:20:42] GET /keep_alive HTTP/1.1" 200 -
2022-07-03T02:20:41.782478645Z,stdout,Keep alive!
2022-07-03T02:15:41.678059022Z,stderr,127.0.0.1 - - [03/Jul/2022 02:15:41] "GET /keep_alive HTTP/1.1" 200 -
2022-07-03T02:15:41.191699233Z,stdout,Keep alive!
2022-07-03T02:10:41.087022297Z,stderr,127.0.0.1 - - [03/Jul/2022 02:10:41] "GET /keep_alive HTTP/1.1" 200 -
2022-07-03T02:10:40.597110047Z,stdout,Keep alive!
2022-07-03T02:05:40.495164846Z,stderr,127.0.0.1 - - [03/Jul/2022 02:05:40] "GET /keep_alive HTTP/1.1" 200 -
2022-07-03T02:05:40.028083982Z,stdout,Keep alive!
2022-07-03T02:00:39.925701641Z,stderr,127.0.0.1 - - [03/Jul/2022 02:00:39] "GET /keep_alive HTTP/1.1" 200 -
2022-07-03T02:00:39.423381390Z,stdout,Keep alive!
2022-07-03T01:59:30.948734287Z,stderr,192.168.1.241 - - [03/Jul/2022 01:59:30] "GET /play/recipe_tv.m3u8 HTTP/1.1" 302 -
2022-07-03T01:59:30.513201439Z,stdout,"channel/live/recipe_tv > https://sr-live2-frndly.akamaized.net/v1/master/840a24ccd7c75076211d060179b3ad0c64fdc6ca/live_v2_nr_new/dbfd8439e2bd4a9b97b9fbc9a98bacc2/index.m3u8?ads.rating=tvg&ads.title=a%255Ftaste%255Fof%255Fireland&ads.contenttype=live&ads.app_store_url=https://play.google.com/store/apps/details?id=com.tvapp.frndlytv&ads.app_bundle=com.tvapp.frndlytv&ads.station=recipetv&ads.us_privacy=1YNY&ads.duration=1800000&ads.genre=food%252Ccooking%252Cinstruction&ads.did=d36cc1c5-945b-32fa-ae11-d2e87e215a3f&hdnts=st=1656813570~exp=1656835170~acl=!*/v1/master/840a24ccd7c75076211d060179b3ad0c64fdc6ca/live_v2_nr_new/dbfd8439e2bd4a9b97b9fbc9a98bacc2/*!/payload/yupptvott_43_1181269_SHIELD30X8X4X0_US_172.225.20.133, 65.30.226.226_frndlytv_1_channel_19_-1/*~data=yupptvott_43_1181269_SHIELD30X8X4X0_US_172.225.20.133, 65.30.226.226_frndlytv_1_channel_19_-1~hmac=159b678938fda13a490e778bd373a8430033faf9f5c831e2bed38966e367bbf3
Errors on the frndly servers. As noted by others the same behavior is happening in their app.
Looks like FRIENDLY TV ad insertion is down.
Hopefully, they get it back up and operational.
Most channels on the service have insertion several times an hour.
@matthuisman
Matt, not sure how soon is soon, but
Movies! channel is coming soon to Frndly TV
tvc-guide-stationid="81275" seems to match their website schedule.
thanks. ill put a note in but I can't add it until I know frndly-tvs channel id for it as I map that to the epg id. I suspect it will be 49 but will wait and see. Ping me once its live
Hello @matthuisman, I've noticed that there are 3 new channels on Frndly,
Dove Channel - Kids
Dove Family Movies
Crime + Investigation
I don't know how hard it is to fix, but it sure would be great!
Thanks
