I'm running Channels DVR on Windows 10 and using the Python version of Frndly TV
Last night, the Frndly Hallmark channels stopped working with a FFmpeg/codec errors. Other Frndly TV channels are streaming just fine. I just updated the Channels DVR to the pre-release, but still get the error.
I can watch Hallmark via Frndly's website and with TVE.
/08/31 19:31:53.372092 [TNR] Opened connection to M3U-Frndly for ch9002 Hallmark Channel
2022/08/31 19:31:53.378864 [HLS] Starting live stream for channel 9002 from [127.0.0.1](http://127.0.0.1/) (bitrate=27641)
2022/08/31 19:32:03.806423 [HLS] Probe failed for live stream after 10.4264404s and 0 bytes
2022/08/31 19:32:08.145496 [HLS] Couldn't generate stream playlist for ch9002-dANY-ip127.0.0.1: Timeout waiting for session to start after 8s
2022/08/31 19:32:08.145496 [HLS] Stopping transcoder session ch9002-dANY-ip127.0.0.1 (out: 0s, finished: false)
2022/08/31 19:32:08.199958 [HLS] ffmpeg: ch9002-dANY-ip127.0.0.1-remux: pipe:: could not find codec parameters
2022/08/31 19:32:08.272686 [TNR] Closed connection to M3U-Frndly for ch9002 Hallmark Channel
2022/08/31 19:32:08.272686 [SNR] Buffer statistics for ch9002 Hallmark Channel: buf=0% drop=0%
2022/08/31 19:32:10.074740 [TNR] Opened connection to M3U-Frndly for ch9002 Hallmark Channel
2022/08/31 19:32:10.081953 [HLS] Starting live stream for channel 9002 from [127.0.0.1](http://127.0.0.1/) (bitrate=27641)
2022/08/31 19:32:16.920362 [NAT] Failed to discover upnp routers
2022/08/31 19:32:16.920362 [NAT] Failed to discover router using natpmp and upnp.
2022/08/31 19:32:17.337963 [HLS] Couldn't generate stream playlist for ch9002-dANY-ip127.0.0.1: Timeout waiting for session to start after 8s
2022/08/31 19:32:17.337963 [HLS] Stopping transcoder session ch9002-dANY-ip127.0.0.1
2022/08/31 19:32:17.536952 [HLS] Probe failed for live stream after 7.4544916s and 0 bytes
2022/08/31 19:32:17.542209 [HLS] ffmpeg: ch9002-dANY-ip127.0.0.1-remux: pipe:: could not find codec parameters
2022/08/31 19:32:17.582332 [TNR] Closed connection to M3U-Frndly for ch9002 Hallmark Channel
2022/08/31 19:32:19.087071 [TNR] Opened connection to M3U-Frndly for ch9002 Hallmark Channel
2022/08/31 19:32:19.093551 [HLS] Starting live stream for channel 9002 from [127.0.0.1](http://127.0.0.1/) (bitrate=27641)
2022/08/31 19:32:21.799057 [HLS] Stopping transcoder session ch9002-dANY-ip127.0.0.1
2022/08/31 19:32:23.454983 [HLS] Probe failed for live stream after 4.3612397s and 0 bytes
2022/08/31 19:32:23.459162 [HLS] ffmpeg: ch9002-dANY-ip127.0.0.1-remux: pipe:: could not find codec parameters
2022/08/31 19:32:23.509117 [TNR] Closed connection to M3U-Frndly for ch9002 Hallmark Chann
