Frndly TV for Channels
No, comes back with null response.
I get a “server unexpectedly dropped the connection” using Safari on a Mac. MS Edge on system running container has a dropped connection. Base URL responds just fine. The /play/xx paths all fail.
you have a valid subscription right?
You can watch channels via the frndly tv website etc?
Just pushed a new docker image that should report back in the browser the error it gets from frndly.
Please update your docker container to the latest, and then see what error you get.
Comes back with:
Error: You are not logged in
Thank you for adding that very helpful diagnostic to the /play/xx page. I discovered I had a capitalization error in the password string. Fixing that and rerunning the container the /play/xx page now returns a master.m3u8.
I feel very sheepish for missing the capitalization error and very grateful for your effort to return the very helpful diagnostic message to trigger the investigation.
Many thanks once again.
no worries - i'll see if I can update the container to error on the playlist as well if it knows your not logged in :slight_smile:
UPDATE:
Latest container will error when trying to get a playlist without being logged in
Thank You. This is exactly what I wanted to get back the Weather Channel. Awesome. Had a terrible time getting Docker Desktop to run. But that was specific to me and my use of a VPN. If you use PIA for a VPN you need go to PIA settings, Split Tunnel, and set Name Servers to VPN DNS ONLY. That'll get Docker Desktop to work on your system.
Now lets hope Allen Media Group doesn't revoke Fndly's license after the Weather Channel Plus steaming service comes out in the next few months.
Windows 10 Home 19042.1288
Server Version 2021.10.19.2206
Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz 2.71 GHz
Frndly added GAC Family and GAC Living.
Does the app need an update for the new channels?
I was wondering the same thing too.
@matthuisman ? :slightly_smiling_face:
Re: GAC Family and GAC Living
How often does Frndly TV for Channels docker update the playlist from frndlytv.com?
If it's like Pluto for Channels, then every three hours.
Have you tried reloading the Playlist M3U or restarting the Frndly TV for Channels docker container?
I installed and started the latest docker image but the new channels do not pull in. Does the docker app pull in these channels as the docker is written, or does the docker need to be updated to recieve the new channels added on their site. Assumed that its written to pull in new channels if available like Pluto and Stirr contaners do.
I'm not a coder, but someone familiar with python would know.
To me, it looks like it's hard coded https://github.com/matthuisman/frndlytv-for-channels/blob/master/app.py as LIVE_MAP= and the docker image needs updating.
just pushed new docker image that should enable the latest channels.
Latest container now uses an external map file (https://i.mjh.nz/frndly_tv/app.json) so channels can be updated from now on without updating the container.
There are two reasons it needs a map
  1. To map the gracenote ID's otherwise no EPG
  2. Frdnly dont return the stream url with the list of channels. To get it, you must call 2x other api calls with the current EPG item playing to obtain it. Therefore, this relies on the container having the correct time. To avoid this, I just find the correct slug that is needed and store that in the map as well.
Sorry for the delay - weekends for me are mostly family time.
And Monday here was a public holiday so long weekend.
Thanks Matt for the update, worked as expected.
Is this something that we will have to do manually or will any new channels automaticaly pull in when they come available. If this is a file to be edited where would I find it.
Answered above:
I am still unable to remap CuriosityStream -> Curiosity Channel.
When I select it in the menu, the window closes, and then when I open it again to see if it got it, this is what I see:
It's like it selects two things even though I clicked on only one (Curiosity Channel).
This is in Chrome.
Thank you, @matthuisman. I have the 2 GAC channels now. :slight_smile:
It won't let you use "Curiosity Channel" because it has no Gracenote stationId associated with it.
If the EPG guide is mapped to the wrong Gracenote stationId and everyone is seeing the wrong guide info for the channel, perhaps @matthuisman can change it in the hosted app.json to use the correct stationId, instead of 120084 "16": [120084, "curiositystream"].
Does anyone know what the correct stationId is for Curiosity Channel?
In another thread, I got very interesting results using this docker in Channels DVR. I think it should be mentioned in this thread too.
