What is the FrndlyTV for Channels docker running on?
Is it at 192.168.7.109:8187
What does a browser show at http://192.168.7.109:8187
Not sure if they ever fixed this issue.
Try adding it back as a custom m3u source using a different Name/Nickname for the source than you had before.
Also, what timezone environment variable are you passing to the container?
Tried a different name when adding no success
US/Arizona
I don't know.
The error you posted says "Temporary failure in name resolution"
There's also a string in the errors timezone=Pacific%2FAuckland
Yeah I am not sure either, MLB is also doing that, its showing 0 channels.
I would think you want America/Phoenix
In the frndly compose correct? I currently have that in the MLB yaml.
For any docker run or compose you use
Since I'm not fluent in Python code and errors, I'm guessing here.
Could be your password.
Does the docker log show it logged in?
401
Unauthorized access
logging in....
Logged in!
It just displays logging in....
Special characters in your password?
I don't use compose/yaml so not sure how it would handle them.
Special characters indeed, will change it
No luck at all might have to rebuild the container with a new port.
You can view and edit a containers settings (including environment variables, volumes and port) from Synology Container Manager
Stop the container and select Settings to change them
Here's your post from the html export in the correct chronological order (I just reversed the lines).
Maybe @matthuisman or someone familiar with the Python code could tell you what your error means.
2024/01/29 15:18:09 stdout logging in....
2024/01/29 15:18:19 stderr 192.168.7.109 - - [29/Jan/2024 22:18:19] "GET /playlist.m3u8?gracenote=include HTTP/1.1" 500 -
2024/01/29 15:18:19 stderr ----------------------------------------
2024/01/29 15:18:19 stderr Exception happened during processing of request from ('192.168.7.109', 60832)
2024/01/29 15:18:19 stderr Traceback (most recent call last):
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 174, in _new_conn
2024/01/29 15:18:19 stderr conn = connection.create_connection(
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 72, in create_connection
2024/01/29 15:18:19 stderr for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/socket.py", line 918, in getaddrinfo
2024/01/29 15:18:19 stderr for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
2024/01/29 15:18:19 stderr socket.gaierror: [Errno -3] Temporary failure in name resolution
2024/01/29 15:18:19 stderr During handling of the above exception, another exception occurred:
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 703, in urlopen
2024/01/29 15:18:19 stderr httplib_response = self._make_request(
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 386, in _make_request
2024/01/29 15:18:19 stderr self._validate_conn(conn)
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 1042, in _validate_conn
2024/01/29 15:18:19 stderr conn.connect()
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 363, in connect
2024/01/29 15:18:19 stderr self.sock = conn = self._new_conn()
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 186, in _new_conn
2024/01/29 15:18:19 stderr raise NewConnectionError(
2024/01/29 15:18:19 stderr urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7ff2ae0d0a60>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 489, in send
2024/01/29 15:18:19 stderr resp = conn.urlopen(
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 787, in urlopen
2024/01/29 15:18:19 stderr retries = retries.increment(
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 592, in increment
2024/01/29 15:18:19 stderr raise MaxRetryError(_pool, url, error or ResponseError(cause))
2024/01/29 15:18:19 stderr urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='frndlytv-api.revlet.net', port=443): Max retries exceeded with url: /service/api/v1/get/token?box_id=SHIELD30X8X4X0&device_id=43&tenant_code=frndlytv&device_sub_type=nvidia%2C8.1.0%2C7.4.4&product=frndlytv&display_lang_code=eng&timezone=Pacific%2FAuckland (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7ff2ae0d0a60>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/socketserver.py", line 683, in process_request_thread
2024/01/29 15:18:19 stderr self.finish_request(request, client_address)
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/socketserver.py", line 360, in finish_request
2024/01/29 15:18:19 stderr self.RequestHandlerClass(request, client_address, self)
2024/01/29 15:18:19 stderr File "./app.py", line 25, in __init__
2024/01/29 15:18:19 stderr super().__init__(*args, **kwargs)
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/socketserver.py", line 747, in __init__
2024/01/29 15:18:19 stderr self.handle()
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/http/server.py", line 435, in handle
2024/01/29 15:18:19 stderr self.handle_one_request()
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/http/server.py", line 423, in handle_one_request
2024/01/29 15:18:19 stderr method()
2024/01/29 15:18:19 stderr File "./app.py", line 55, in do_GET
2024/01/29 15:18:19 stderr self._error(e)
2024/01/29 15:18:19 stderr File "./app.py", line 53, in do_GET
2024/01/29 15:18:19 stderr routes[func]()
2024/01/29 15:18:19 stderr File "./app.py", line 71, in _playlist
2024/01/29 15:18:19 stderr channels = frndly.channels()
2024/01/29 15:18:19 stderr File "/usr/src/app/frndly.py", line 150, in channels
2024/01/29 15:18:19 stderr rows = self._request('https://frndlytv-api.revlet.net/service/api/v1/tvguide/channels?skip_tabs=0')['data']
2024/01/29 15:18:19 stderr File "/usr/src/app/frndly.py", line 116, in _request
2024/01/29 15:18:19 stderr self.login()
2024/01/29 15:18:19 stderr File "/usr/src/app/frndly.py", line 186, in login
2024/01/29 15:18:19 stderr headers['session-id'] = requests.get('https://frndlytv-api.revlet.net/service/api/v1/get/token', params=params, headers=headers, timeout=TIMEOUT).json()['response']['sessionId']
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 73, in get
2024/01/29 15:18:19 stderr return request("get", url, params=params, **kwargs)
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 59, in request
2024/01/29 15:18:19 stderr return session.request(method=method, url=url, **kwargs)
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 587, in request
2024/01/29 15:18:19 stderr resp = self.send(prep, **send_kwargs)
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 701, in send
2024/01/29 15:18:19 stderr r = adapter.send(request, **kwargs)
2024/01/29 15:18:19 stderr File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 565, in send
2024/01/29 15:18:19 stderr raise ConnectionError(e, request=request)
2024/01/29 15:18:19 stderr requests.exceptions.ConnectionError: HTTPSConnectionPool(host='frndlytv-api.revlet.net', port=443): Max retries exceeded with url: /service/api/v1/get/token?box_id=SHIELD30X8X4X0&device_id=43&tenant_code=frndlytv&device_sub_type=nvidia%2C8.1.0%2C7.4.4&product=frndlytv&display_lang_code=eng&timezone=Pacific%2FAuckland (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7ff2ae0d0a60>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution'))
My best guess is DNS resolution failed looking up the host frndlytv-api.revlet.net
I just find it odd that this started to occur for the frndly and MLB containers.
yup. dns not resolving. if your using ISP dns - switch to something like 1.1.1.1
Is your NAS (and containers running on it) using the same DNS server as the rest of your home network?
I have everything on my home network using my routers LAN IP address for their DNS Server and my router uses Cloudflare DoH.
Yes everything is running together just different ports. Not sure how I can change my dns settings on my synology.
Change it in Control Panel > Network.
If your main router acts as a DHCP server for everything you can have the Synology get it's reserved DHCP IP address from it as well as having your main router act as the DNS server for your LAN, then set the Internet DNS server you want everything to use on your router.
@chDVRuser I did a restart of my NAS and it its now working, I did not change the DNS settings. I was able to add frndly as a source again. Thank you so much for your assistance and knowledge.
