Frndly TV for Channels
Hello. The IP address & Port for Channels is the same as before (if that's what you're referencing). HDHomerun channels and Frontier Fios channels all work. My server IP was set to static before and after Windows reinstall. I'm not sure if that's the issue - but I could be wrong
Hi. Yes, I did use my actual username/password
It's not. I'm talking about the IP and port of your FrndlyTV container, which is used in the URL for your Custom Channels Source M3U.
Can you see the container web UI
Screenshot 2026-09-19 103606
