FS issues no CC on OTA
I'm running the Beta version but can't post there so... For some reason none of my OTA stations from my 4K flex are displaying CC. My TiVo streamer has no issue with CC, what's wrong? I uninstalled and reinstalled with no improvement. MY TVE stations are fine.
Also have Alpha version issues, where are I check on these?
FS 4K Max w/external memory added
Your OTA channels are ATSC 1.0 or ATSC 3.0? I read that the type of CC used with ATSC 3.0 is not supported in Channels.
90% of my ATSC 3 stations are using DRM and therefore worthless so I removed them all. The problem occurs with the ATSC 1.0 stations.
Channels seems to be able to display CC's as defined in FireTV Accessibility options. I turn on the Closed Captions there and define the Text so it displays how I want in Channels. Maybe there is a difference the way TVE is able to handle CC.
