I tried to use the docker command but said it could not find the image locally and wouldn't try to pull that image whatsoever. Is there a different command I should be running?
Also getting this with the original docker file from @joagomez by re adding it to the sources. I guess this is finally done for.
invalid source url: Get "http://192.168.254.19:7777/fubo/playlist-hls.m3u": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
