Channels can tune to the USA channel now, but I still just see the "NO SIGNAL" image which is the same image I see in the LinkPi console. If I reboot the Osprey, I briefly see the DirecTV logo and boot, but the end result is the same:
Last updated: 9/15/2025, 6:52:16 PM
2025/09/15 18:51:13 [START] ah4c is starting
2025/09/15 18:51:13 [ENV] Not loading env
2025/09/15 18:51:13 [ENV] IPADDRESS 10.10.10.10:7654
2025/09/15 18:51:13 [ENV] ALERT_SMTP_SERVER smtp.gmail.com:587
2025/09/15 18:51:13 [ENV] ALERT_AUTH_SERVER smtp.gmail.com
2025/09/15 18:51:13 [ENV] ALERT_EMAIL_FROM [email protected]
2025/09/15 18:51:13 [ENV] ALERT_EMAIL_PASS fciojjiplxbpmrtz
2025/09/15 18:51:13 [ENV] ALERT_EMAIL_TO [email protected]
2025/09/15 18:51:13 [ENV] ALERT_WEBHOOK_URL
2025/09/15 18:51:13 [ENV] ALLOW_DEBUG_VIDEO_PREVIEW
2025/09/15 18:51:13 [ENV] Creating tuner 1
2025/09/15 18:51:13 [ENV] ENCODER1_URL http://10.10.10.25/live/stream0
2025/09/15 18:51:13 [ENV] TUNER1_IP 10.10.10.24:5555
2025/09/15 18:51:13 [ENV] CMD1
2025/09/15 18:51:13 [ENV] TEECMD1
2025/09/15 18:51:13 [ENV] PRE SCRIPT ./scripts/osprey/dtvosprey/prebmitune.sh
2025/09/15 18:51:13 [ENV] START SCRIPT ./scripts/osprey/dtvosprey/bmitune.sh
2025/09/15 18:51:13 [ENV] STOP SCRIPT ./scripts/osprey/dtvosprey/stopbmitune.sh
2025/09/15 18:51:13 [ENV] REBOOT SCRIPT ./scripts/osprey/dtvosprey/reboot.sh
2025/09/15 18:51:13 [START] ah4c is ready
2025/09/15 18:51:29 Attempting network tune for device http://10.10.10.25/live/stream0 10.10.10.24:5555 242
2025/09/15 18:51:29 [EXECUTE] Running [./scripts/osprey/dtvosprey/prebmitune.sh 10.10.10.24:5555 242]
2025/09/15 18:51:33 [EXECUTE] Stdout: 'already connected to 10.10.10.24:5555
Waking 10.10.10.24:5555
prebmitune.sh is exiting for 10.10.10.24:5555 with exit code 0
2025/09/15 18:51:33 [EXECUTE] Stderr: '+ streamerIP=10.10.10.24:5555
+ streamerNoPort=10.10.10.24
+ adbTarget='adb -s 10.10.10.24:5555'
+ mkdir -p 10.10.10.24
+ trap finish EXIT
+ main
+ adbConnect
+ adb connect 10.10.10.24:5555
+ local -i adbMaxRetries=3
+ local -i adbCounter=0
+ true
+ adb -s 10.10.10.24:5555 shell input keyevent KEYCODE_WAKEUP
+ local adbEventSuccess=0
+ [[ 0 -eq 0 ]]
+ break
+ adbWake
+ sleep 2
+ echo 'Waking 10.10.10.24:5555'
+ touch 10.10.10.24/adbAppRunning
+ finish
+ echo 'prebmitune.sh is exiting for 10.10.10.24:5555 with exit code 0'
2025/09/15 18:51:33 [EXECUTE] Finished running ./scripts/osprey/dtvosprey/prebmitune.sh in 4.023474502s
2025/09/15 18:51:33 [EXECUTE] Running [./scripts/osprey/dtvosprey/bmitune.sh 242 10.10.10.24:5555]
2025/09/15 18:51:34 [EXECUTE] Stdout: 'bmitune.sh is exiting for 10.10.10.24:5555 with exit code 0
2025/09/15 18:51:34 [EXECUTE] Stderr: '+ channelID='"242"'
+ specialID=242
+ m3uName=dtvosprey.m3u
+ trap finish EXIT
+ main
+ matchEncoderURL
+ case "$streamerIP" in
+ encoderURL=http://10.10.10.25/live/stream0
+ tuneChannel
+ adb -s 10.10.10.24:5555 shell input text '"242"'
+ finish
+ echo 'bmitune.sh is exiting for 10.10.10.24:5555 with exit code 0'
