Is there a way to get a spreadsheet of the full Gracenote/guide data for all channels? Sometimes the search can be finicky, and you need to be very specific with the channel names for it to populate correctly.
Any help is appreciated.
Unclear exactly what you're looking for.
Best to give an example of what you want to see.
Th eonly way I know how to get the graceid number fo ryour channel is through this website:
https://tvlistings.gracenote.com/grid-affiliates.html?aid=orbebb#
Put your zipcode in and select a provider. Search the channel you want and then right click on the channel logo and select open in new tab. In the link will be find a number that is the graceid for that channel.
Example:
https://zap2it.tmsimg.com/h3/NowShowing/10809/s10003_ll_h15_ac.png?w=55
10809 is the graceid for this channel.
This is very helpful.
Can i put that number right back into channels when matching?
I was hoping to get a global list of callsigns and the station names
for your channels, or ALL gracenote?
End-users do not have access to such a table. You can, however, do this to get accurate results:
If you don't want to install MTM, the same advice written there is true when using the search in Channels. You'll just have to go to the listing website yourself to get the short text codes you'll need:
this has been crazy helpful ty!
Here is a decent Gracenote list.
Not sure if possible, but a I have ben trying to find a way to find gracenote guide data of what is coming up. Specifically for Sunday Ticket games, where they are listed as 1,2,3,4 but I do not know which match up will be on which
might take some experimentation on your side, but @zerodayz posted a list that has NFL Sunday Ticket channels.
CAN-0005993-X CAN 44452 NFLHD1 NFL Sunday Ticket NFL1 (HDTV)
CAN-0005993-X CAN 61431 NFLHD10 NFL Sunday Ticket NFL10 (HDTV)
CAN-0005993-X CAN 61432 NFLHD11 NFL Sunday Ticket NFL11 (HDTV)
CAN-0005993-X CAN 61433 NFLHD12 NFL Sunday Ticket NFL12 (HDTV)
CAN-0005993-X CAN 61434 NFLHD13 NFL Sunday Ticket NFL13 (HDTV)
CAN-0005993-X CAN 61435 NFLHD14 NFL Sunday Ticket NFL14 (HDTV)
CAN-0005993-X CAN 61436 NFLHD15 NFL Sunday Ticket NFL15 (HDTV)
CAN-0005993-X CAN 61439 NFLHD16 NFL Sunday Ticket NFL16 (HDTV)
CAN-0005993-X CAN 61440 NFLHD17 NFL Sunday Ticket NFL17 (HDTV)
CAN-0005993-X CAN 61441 NFLHD18 NFL Sunday Ticket NFL18 (HDTV)
CAN-0005993-X CAN 44453 NFLHD2 NFL Sunday Ticket NFL2 (HDTV)
CAN-0005993-X CAN 44454 NFLHD3 NFL Sunday Ticket NFL3 (HDTV)
CAN-0005993-X CAN 44455 NFLHD4 NFL Sunday Ticket NFL4 (HDTV)
CAN-0005993-X CAN 44456 NFLHD5 NFL Sunday Ticket NFL5 (HDTV)
CAN-0005993-X CAN 44457 NFLHD6 NFL Sunday Ticket NFL6 (HDTV)
CAN-0005993-X CAN 44458 NFLHD7 NFL Sunday Ticket NFL7 (HDTV)
CAN-0005993-X CAN 44459 NFLHD8 NFL Sunday Ticket NFL8 (HDTV)
CAN-0005993-X CAN 44529 NFLHD9 NFL Sunday Ticket NFL9 (HDTV)
USA-CA02268-X USA 47216 NFLRZ NFL SUNDAY TICKET RED ZONE
Yea, I have the gracenote ID, now I want to see how easy it is to see an upcoming guide for that channel somehow.
For example, Rams vs Bears is on a Sunday ticket channel coming up this weekend. I don't know which one, how can I look to see which channel it is on without putting a dummy EPG download into channels.
