Here in San Diego, ATSC 3.0 channels 106.1, 151.1, and 169.1 have started broadcasting recently. They are enabled in my source list and I can view them just fine. But, there is no guide data. Will these channels be added soon?
In Channels DVR they should map to the ATSC 1 guide data. On the source try sync station mapping.
And if it doesn't automatically sync correctly (I have this issue with one ATSC 3.0 station), you can manually map it:
I did try Sync Station Mapping, Reload Lineup, and Redownload Guide. Nothing changed.
Ok, figured out how to do that. Clicked on the grey + and chose the channel it should be mapped to. Couldn't find 106.1 That is a low power station. Have to figure out if that has a mapping.
"106.1" in San Diego is just Jewelry TV as KRPE-LD needed to put something on their ATSC 3.0 signal so they can keep their LPTV license and continue leasing out their 87.7 audio carrier to a franken FM operator. If you want to map listings to it, use JTVHD (65556)
Thanks! It was playing Forensic Files when I first looked and is now playing a Fred Astaire dancing movie. Doesn't sound like the same content.
Editing to add I just saw a logo. It is AMG TV.
Ah, they must have changed recently then. Use AMGTV (55916)
I switched my Sunday night Fox passes to 169.1 and it appeared to have the same guide data as 69.1, but it recorded something other than The Simpsons episode that was in the guide last Sunday. It definitely aired on the regular station because I was able to watch it from the Youtube TV DVR as broadcast on 69.1. I'll keep an eye on it over the weekend and see if the guide corresponds to what's being broadcast.
