Anyone get a good deal lately on a Harmony Hub remote and want to share? The Companion remote especially, but any hub deal will be appreciated.
Got a refurbished one from woot recently for a good price. No guarantee they will get more, but maybe worth signing up for their newsletter just in case.
On 9 to 5 blog
In a blog post (via TechHive ), Logitech says “Harmony remotes are and continue to be available through various retailers, moving forward Logitech will no longer manufacture Harmony remotes.”
“We expect no impact to our customers by this announcement. We plan to support our Harmony community and new Harmony customers, which includes access to our software and apps to set up and manage your remotes. We also plan to continue to update the platform and add devices to our database. Customer and warranty support will continue to be offered.”
I got the same one, for $60, knowing full well its future is limited. For what it does in my living room, it's been worthwhile. The "smart home" integration is clunky and limited, but I knew that going in. Still worth it at that price, even if it only lasts a few years. Hopefully a new player will enter this space, to take over in a few years when hardware has to change.
The concern I have is that the Hubs need a connection to the Harmony Server for it to work. Someday Logitech will either shut them down or charge a subscription fee. (It is beginning to feel like the path Wink took.)
Yes most likely. Maybe a couple years out though.
Sell it ?
To be specific, they don’t need this to work. They just need this to be programmed.
True, but as soon as you replace out a device or need to add a new device you'll be out of luck.
I don't know, my harmony works well but I'm finding I'm going back to the shield remote more because it has built in voice searching... I'm also finding I'm not using the number buttons like I thought I would.... I'm considering just selling it, but the wife likes it now.
You also need the Harmony Server if you are using the app on your phone or tablet.
I have been playing around with just using the Shield remote because I was able to assign the power button to turn on my AVR, TV and Shield device so I don't need the Harmony remote for that one.
I am beginning to like it better anyway - the buttons are lighted (I have the Harmony Companion remote so no lights on it) and I find I am using the voice button on the Shield remote more often.
I may end up freeing myself up from even needing the Harmony remote at all.
They are not going to manufacture it but it will be supported as long it's in use. I don't really know what that means your guess is as good as mine. You can use without cloud but can't have link's to other services (Alexa, KASA...) without the cloud.
We at Home Assistant are keeping a close eye on YIO Remote which is a fully open source yet very well put together Harmony competitor. Their new model is coming out later this year and we are in active discussions with them to see how we can best enable it to work with HA natively.
One work around is to connect your harmony hub to your Google assistant. The you can use voice controls to do control much of your hub setup. Works especially well when combined with the new shield remote
Should also work with Amazon echo
