HD HomeRun tuner was working fine with Channels DVR on FireTV 4k but now does not. It shows up as a tuner with the correct IP address but there are no channels.
This started when I changed the IP address of the HDHR. The correct IP address is listed.
Everything works normally from the Channels DVR computer and recordings are working as they should.
Any ideas?
Oh - by the way, I've restarted everything, I've cleared the app data on the FireTV Stick, I've removed and re-installed the app on the FireTV stick and I also tried the beta version of the app. No change with the the tuner.
