Busy this morning but I may be able to oblige later this evening. I want to write it down any way incase I do it again. What NAS do you have?
My nas is the WD Mycloud 2tb
These are pretty detailed from SD.
https://www.silicondust.com/forum/viewtopic.php?f=92&t=20526
The problem is with Step 4 you need download the 2016-04-26 Release.
http://download.silicondust.com/hdhomerun/hdhomerun_record_linux_20160426atest1
The Link is not documented so be sure to make a copy of the file.
Since you are already installed you just need to replace the hdhomerun_record file in the HDHomeRun Share / Folder with this old one from 04/26. Then do the Stop/Start via SSH (could be hardest part if not familiar with SSH and you are on Windows and have to use Putty. The Mac is easier for using SSH.
Thank you!!! Finally got it working this morning!
