The extra :7654 is the problem. We changed a while back to using the port together with the IP address rather than hard-coded in the M3U. Scripts and M3U files are not replaced automatically, so yours may be from before the change. The port should be together with the hostname or IP in the IPADDRESS environment variable (which it appears to be, and is why it's doubled).
The current directv.m3u should look something like this:
#EXTM3U
#EXTINF:-1 channel-id="8" tvc-guide-stationid="25102",KAET PBS 8
http://{{ .IPADDRESS }}/play/tuner/8
#EXTINF:-1 channel-id="10" tvc-guide-stationid="21209",KSAZ FOX 10
http://{{ .IPADDRESS }}/play/tuner/10
#EXTINF:-1 channel-id="12" tvc-guide-stationid="20507",KPNX NBC 12
http://{{ .IPADDRESS }}/play/tuner/12
#EXTINF:-1 channel-id="212" tvc-guide-stationid="45399",NFL Network HD
http://{{ .IPADDRESS }}/play/tuner/212
#EXTINF:-1 channel-id="216" tvc-guide-stationid="45526",NBA TV HD
http://{{ .IPADDRESS }}/play/tuner/216
#EXTINF:-1 channel-id="217" tvc-guide-stationid="60316",Tennis Channel HD
http://{{ .IPADDRESS }}/play/tuner/217
#EXTINF:-1 channel-id="219" tvc-guide-stationid="82547",FOX Sports 1 HD
http://{{ .IPADDRESS }}/play/tuner/219
#EXTINF:-1 channel-id="241" tvc-guide-stationid="59186",Paramount Network HD
http://{{ .IPADDRESS }}/play/tuner/241
#EXTINF:-1 channel-id="242" tvc-guide-stationid="58452",USA Network HD
http://{{ .IPADDRESS }}/play/tuner/242
#EXTINF:-1 channel-id="501" tvc-guide-stationid="19548",HBO HD East
http://{{ .IPADDRESS }}/play/tuner/501
#EXTINF:-1 channel-id="502" tvc-guide-stationid="59368",HBO2 HD East
http://{{ .IPADDRESS }}/play/tuner/502
#EXTINF:-1 channel-id="503" tvc-guide-stationid="59363",HBO Signature HD East
http://{{ .IPADDRESS }}/play/tuner/503
#EXTINF:-1 channel-id="504" tvc-guide-stationid="19566",HBO West HD
http://{{ .IPADDRESS }}/play/tuner/504
#EXTINF:-1 channel-id="505" tvc-guide-stationid="59355",HBO2 West HD
http://{{ .IPADDRESS }}/play/tuner/505
#EXTINF:-1 channel-id="506" tvc-guide-stationid="59839",HBO Comedy HD
http://{{ .IPADDRESS }}/play/tuner/506
#EXTINF:-1 channel-id="507" tvc-guide-stationid="59357",HBO Family East HD
http://{{ .IPADDRESS }}/play/tuner/507
#EXTINF:-1 channel-id="509" tvc-guide-stationid="59845",HBO Zone HD
http://{{ .IPADDRESS }}/play/tuner/509
#EXTINF:-1 channel-id="618" tvc-guide-stationid="59305",FOX Sports 2 HD
http://{{ .IPADDRESS }}/play/tuner/618
#EXTINF:-1 channel-id="exit" tvg-logo="http://{{ .IPADDRESS }}/static/logos/exit.png",Exit DirecTV
http://{{ .IPADDRESS }}/play/tuner/exit
#EXTINF:-1 channel-id="reboot" tvg-logo="http://{{ .IPADDRESS }}/static/logos/reboot.png",Reboot FireTV
http://{{ .IPADDRESS }}/play/tuner/reboot
You could hand edit the file to remove the hard-coded :7654, or delete the m3u file (and the firetv/directv scripts for that matter to get the latest), which is probably a better option. You can rename your scripts and current m3u if you've modified them and want to integrate your previous work into the new files.
Once you've deleted the files, go into Portainer-Stacks and update (use the slider to get the latest image too). Check the Portainer logs for the container, and you should see the latest scripts and m3u file copied over to your data directory.
