I recently had to install a new hard drive & reinstall everything & i cant find the correct pluto m3u & epg list that works with docker. Im not looking for the non docker version, which is what i found.
Thanks
If i can ask a question, if I install maddox docker pluto for channels, then would I still have to add a m3u & epg guide manually?
The Docker will provide the M3U and XML links which you add to Channels DVR
Ok great. Im gonna try that now.
ok everything worked & wanted to say thank you.
