Tested with a custom M3U source (Stream Format HLS: H.264 + AAC, a WebVTT subtitle track, and EIA-608 in the video), on Apple TV and iPhone (Channels app 7.1.2), DVR ffmpeg 6.0.2.
Delivery paths
Direct (local, Original): the app fetches
/devices/…/channels/N/stream.mpg. No ffmpeg runs; the DVR passes the TS through. WebVTT and 608 both reach the app. Recordings are the same raw TS, so they keep both tracks too. -
Stream (HLS) at Original:
master.m3u8?codec=copy&format=copy→ ffmpeg remux (-c:v copy -c:a copy -c:s copy -f hls -hls_passthrough_subtitles 1). WebVTT ends up as a private data stream and the master playlist has no SUBTITLES group, so the app shows nothing. 608 stays in the video. -
Reduced quality: the app only sends
?bitrate=N. If N is above the source rate, it's still the plain remux. Below it, a second ffmpeg transcodes (libx264 veryfast,fastdeint=blend, scaled to 720p, or 384p around 300 kbps, with-b:v/-minrate/-maxrate). 608 survives the transcode; WebVTT doesn't. -
Remote: even "Original" uses the HLS remux, and on cellular the app's adaptive bitrate stepped down to a 384p transcode within a minute. So remotely only 608 works. The quality choice is entirely client-side; on the server, a VPN client that connects directly counts as local, and any
X-Forwarded-Forheader makes a request remote (auth required). - Audio: AAC is copied (re-encoded to stereo at low bitrates); AC-3 is re-encoded to 6-channel AAC 256k.
How the app shows captions (tvOS and iOS)
- WebVTT ("On"): centered, but only available on Direct. Cue end times are ignored: a caption stays until the next one replaces it.
- 608 ("Track 2"): works on every path, but is always drawn in a left-anchored box. PAC column/tab offsets are ignored, and leading spaces and transparent spaces are trimmed. Even a full 32-column row sits on the left.
- 708 only: not shown at all.
Takeaway: for remote viewers, embed 608. For centered text at home, add WebVTT (Direct only).
What would help
- Pass WebVTT through the HLS remux/transcode as a real SUBTITLES rendition.
- Honor 608 positioning (PAC indent / column).
- Honor WebVTT cue end times.
