How often does the guide update?
And is there an easy way to force an update? I record the late shows looking for band performances and the guide is showing most of them with the generic description. And I know that all the shows are new next week. I could change my passes from New to All Episodes but I’d rather only record the new episodes.
Guide updates once a day around 9am. The next days of data are refreshed. Further out items won’t update until they get closer.
You can force a refresh using the circle icon under your HDHR on the settings web UI
A post was split to a new topic: Guide won’t update if NAS set to shutdown
Following these instructions does get the new guide. However, I updated this Saturday at 11:30 am, and the next available guide is starts 2:00 PM Sunday. Everything is blank until then. The DVR looks like it will record tonight’s Saturday shows, but I’m a little worried they won’t.
Also, it would be nice to refresh from the App.
Are you sure the clock on your NAS is set correctly?
So this is weird, I realize that I was using the Channels app (AppleTV) that I originally install a while back, and just installed the Channels DVR app. Now the schedule is updated correctly.
Maybe the new install brought in a new guide or using the non DVR app had issues with my sub.
However, my NAS has been rebooted a couple times last week, I’ll check it too. Thanks.
