I see that in your December SOTU for Channels DVR you list FreeNAS as something have an officially supported package for. However I don’t see instructions for installing to FreeNAS in the installation section for the public beta. Is there a script I can run or do I have to do it manually for FreeNAS?
Thanks. I uploaded that pbi into a new pluginjail but having troubles starting it.
root@customplugin_1:/ # cat /channels-dvr.log
exec: /usr/pbi/channels-dvr-amd64/channels-dvr/latest/channels-dvr: not found
root@customplugin_1:/ # cat /var/log/channels-dvr-fcgi.log
[SYS] Running on 192.168.1.5:12351
I noticed a setup.sh file at /usr/pbi/channels-dvr-amd64 but it is empty. There is not a folder named ‘latest’ there either. I’m running version FreeNAS-9.3-STABLE-201509282017. Should the setup.sh not be empty or is there another step I need to do to get it installed correctly?
Can you delete the jail and try again?
Same result. I did notice an error banner within the FreeNAS gui when trying to start the plugin:
cd: /usr/pbi/channels-dvr-amd64/channels-dvr/data: No such file or directory daemon: process already running, pid: 67945
What does “uname -a” say on your system?
root@customplugin_1:/usr/pbi/channels-dvr-amd64 # uname -a
FreeBSD customplugin_1 9.3-RELEASE-p26 FreeBSD 9.3-RELEASE-p26 #0 r281084+93c588
5: Mon Sep 28 13:25:20 PDT 2015 [email protected]:/tank/home/stable-
builds/FN/objs/os-base/amd64/tank/home/stable-builds/FN/FreeBSD/src/sys/FREENAS.
amd64 amd64
Thanks. What about “find . -ls” in that directory?
root@customplugin_1:/usr/pbi/channels-dvr-amd64 # find . -ls
32909 35 drwxr-xr-x 3 501 staff 11 Jan 15 15:51 .
32913 1 drwxr-xr-x 3 501 staff 3 Dec 2 17:58 ./etc
32916 1 drwxr-xr-x 2 501 staff 3 Dec 6 17:44 ./etc/rc.d
32917 18 -rwxr-xr-x 1 501 staff 453 Dec 6 17:59 ./etc/rc.d/channels_dvr
32914 1 -rw-r--r-- 1 501 staff 15 Dec 2 15:22 ./freenas
32915 18 -rwxr-xr-x 1 501 staff 222 Dec 2 17:57 ./tweak-rcconf
32933 1 -rw-r--r-- 1 root staff 0 Jan 15 15:51 ./setup.sh
32911 6775 -rwxr-xr-x 1 501 staff 6158528 Dec 6 18:20 ./control.fcgi
32966 18 -rw------- 1 root staff 181 Jan 15 15:51 ./.oauth
32912 18 -rw-r--r-- 1 501 staff 779 Dec 3 12:13 ./default.png
32967 1 -rw-r--r-- 1 root staff 37 Jan 15 15:51 ./control.conf
32910 18 -rwxr-xr-x 1 501 staff 456 Dec 5 18:34 ./control
Ok the empty setup.sh is the issue as you guessed.
Try:
It must be failing with an ssl error.
It is indeed an SSL error
root@customplugin_1:/usr/pbi/channels-dvr-amd64 # wget -O setup.sh https://getchannels.com/dvr/setup.sh
--2017-01-15 17:27:31-- https://getchannels.com/dvr/setup.sh
Resolving getchannels.com (getchannels.com)... 2400:cb00:2048:1::6818:714d, 2400:cb00:2048:1::6818:704d, 104.24.112.77, ...
Connecting to getchannels.com (getchannels.com)|2400:cb00:2048:1::6818:714d|:443... failed: No route to host.
Connecting to getchannels.com (getchannels.com)|2400:cb00:2048:1::6818:704d|:443... failed: No route to host.
Connecting to getchannels.com (getchannels.com)|104.24.112.77|:443... connected.
OpenSSL: error:14077410:SSL routines:SSL23_GET_SERVER_HELLO:sslv3 alert handshake failure
Unable to establish SSL connection.
I just tried updating my wget version and that didn’t seem to help. Fetch fails with the same error. I’ll try and that fixed up and maybe it’ll all work after that.
Interesting -
root@customplugin_1:/usr/pbi/channels-dvr-amd64 # openssl s_client -connect getchannels.com:443
CONNECTED(00000004)
71829:error:14077438:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert internal error:/usr/src/secure/lib/libssl/../../../crypto/openssl/ssl/s23_clnt.c:585:
When I try the same against google.com it appears to work fine. I get the same behavior when testing those commands on my Mac. Could be something fishy on my network.
Try updating OpenSSL and ca_root_nss
No luck. Any chance there is a path to that file on the https://channels-dvr.s3.amazonaws.com domain? When I do wget https://channels-dvr.s3.amazonaws.com/freenas/channelsdvr-1.0.4.pbi it downloads that fine.
Strange because I was able to install on a FreeNAS VM and several other users have as well.
What does “wget --version” say?
Oh actually the OpenSSL version is more important.
Is your FreeNAS up to date?
GNU Wget 1.18 built on freebsd9.3.
You know… there is a pending update now that I see. I’ll update that real quick and report back.
I had delayed upgrading FreeNAS 9.3 to 9.10 but your app was enough of a motivation to do it. Looks like that was the solution. I was concerned it would not work because having preexisting 9.3 jails means any new jails in 9.10 use the 9.3 template until you nuke all your jails and start over. Luckily just the base of 9.10 was good enough.
Thanks and sorry for wasting your time. Looks like 9.10+ is a requirement for the FreeNAS plugin.
