A huge thank you for creating this app. The overall quality is impressive; from the user experience to its solid performance and stability. Great job!
I installed 1.0 last night - Linux/Docker/Portainer/Stack/Default-Compose. No modifications / default values only.
Enabled 3 channels I know I can watch: CNBC, BRAVO and MSNOW. Setup took less than 10 minutes, including channels-dvr setup. (i would struggle with cc4c).
I recorded quite a few shows and had live tv on all three channels throughout the day. There were no issues. 100% stable.
This evening I updated to 1.20 (clean install - regression issue with channels otherwise). All three channels now have an issue when being watched, where the channel keeps restarting in new tabs. The 1.0 version does not have the issue.
I tested again with 1.0 and 1.20 and recorded the logs.
In version 1.0:
[2026/02/08 01:44:18.029] Using FFmpeg at: /usr/local/lib/node_modules/prismcast/node_modules/ffmpeg-for-homebridge/ffmpeg
[2026/02/08 01:44:18.030] Loaded 81 channels.
[2026/02/08 01:44:18.426] Chrome ready: Chrome/144.0.7559.109.
[2026/02/08 01:44:18.450] PrismCast is now listening on 0.0.0.0:5589.
[2026/02/08 01:44:18.450] HDHomeRun emulation is now listening on 0.0.0.0:5004 (DeviceID: A22BBC05).
[2026/02/08 01:44:18.663] Update available: v1.2.0 (current: v1.1.0).
[2026/02/08 01:44:57.831] [cnbc-pe1onc] Streaming CNBC (fullscreenApi, FFmpeg).
[2026/02/08 01:46:43.734] [msnow-fa1v8j] Streaming MSNOW (keyboardDynamic, FFmpeg).
[2026/02/08 01:47:08.429] [cnbc-pe1onc] Stream ended after 2m 14s.
[2026/02/08 01:48:24.997] [bravo-wfgzo2] Streaming Bravo (keyboardDynamic, FFmpeg).
[2026/02/08 01:48:38.429] [msnow-fa1v8j] Stream ended after 1m 59s.
[2026/02/08 01:50:48.433] [bravo-wfgzo2] Stream ended after 2m 30s.
In Version 1.20:
[2026/02/08 01:57:54.927] Using FFmpeg at: /usr/local/lib/node_modules/prismcast/node_modules/ffmpeg-for-homebridge/ffmpeg
[2026/02/08 01:57:54.929] Loaded 168 channels.
[2026/02/08 01:57:55.321] Chrome ready: Chrome/144.0.7559.132.
[2026/02/08 01:57:55.346] PrismCast is now listening on 0.0.0.0:5589.
[2026/02/08 01:57:55.346] HDHomeRun emulation is now listening on 0.0.0.0:5004 (DeviceID: 6F6D3806).
[2026/02/08 01:58:49.658] [bravo-63pk78] Streaming Bravo (keyboardDynamic, FFmpeg).
[2026/02/08 01:59:17.661] [WARN] [bravo-63pk78] Detected 10 consecutive tiny segments (1413378 bytes). Capture pipeline appears dead.
[2026/02/08 01:59:21.884] [bravo-63pk78] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 01:59:21.884] [bravo-63pk78] Recovered in 4.2s via tab replacement.
[2026/02/08 01:59:47.661] [WARN] [bravo-63pk78] Detected 10 consecutive tiny segments (555331 bytes). Capture pipeline appears dead.
[2026/02/08 01:59:52.346] [bravo-63pk78] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 01:59:52.347] [bravo-63pk78] Recovered in 4.7s via tab replacement.
[2026/02/08 02:00:19.661] [WARN] [bravo-63pk78] Detected 10 consecutive tiny segments (635638 bytes). Capture pipeline appears dead.
[2026/02/08 02:00:23.233] [msnow-muh96b] Streaming MSNOW (keyboardDynamic, FFmpeg).
[2026/02/08 02:00:23.793] [bravo-63pk78] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 02:00:23.794] [bravo-63pk78] Recovered in 4.1s via tab replacement.
[2026/02/08 02:00:45.328] [bravo-63pk78] Stream ended after 2m 1s. Recoveries: 3 (3Γ tab replacement), avg 4.3s.
[2026/02/08 02:00:53.236] [WARN] [msnow-muh96b] Detected 10 consecutive tiny segments (627446 bytes). Capture pipeline appears dead.
[2026/02/08 02:00:56.002] [msnow-muh96b] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 02:00:56.002] [msnow-muh96b] Recovered in 2.8s via tab replacement.
[2026/02/08 02:01:27.238] [WARN] [msnow-muh96b] Detected 10 consecutive tiny segments (296024 bytes). Capture pipeline appears dead.
[2026/02/08 02:01:29.849] [msnow-muh96b] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 02:01:29.849] [msnow-muh96b] Recovered in 2.6s via tab replacement.
[2026/02/08 02:01:49.296] [cnbc-id7luo] Streaming CNBC (fullscreenApi, FFmpeg).
[2026/02/08 02:02:03.241] [WARN] [msnow-muh96b] Detected 10 consecutive tiny segments (529884 bytes). Capture pipeline appears dead.
[2026/02/08 02:02:06.587] [msnow-muh96b] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 02:02:06.587] [msnow-muh96b] Recovered in 3.3s via tab replacement.
[2026/02/08 02:02:11.299] [WARN] [cnbc-id7luo] Detected 10 consecutive tiny segments (511357 bytes). Capture pipeline appears dead.
[2026/02/08 02:02:14.163] [cnbc-id7luo] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 02:02:14.163] [cnbc-id7luo] Recovered in 2.9s via tab replacement.
[2026/02/08 02:02:15.326] [msnow-muh96b] Stream ended after 1m 55s. Recoveries: 3 (3Γ tab replacement), avg 2.9s.
[2026/02/08 02:03:15.301] [WARN] [cnbc-id7luo] Detected 10 consecutive tiny segments (340950 bytes). Capture pipeline appears dead.
[2026/02/08 02:03:18.145] [cnbc-id7luo] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 02:03:18.145] [cnbc-id7luo] Recovered in 2.8s via tab replacement.
[2026/02/08 02:04:41.302] [WARN] [cnbc-id7luo] Detected 10 consecutive tiny segments (252989 bytes). Capture pipeline appears dead.
[2026/02/08 02:04:43.879] [cnbc-id7luo] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 02:04:43.879] [cnbc-id7luo] Recovered in 2.6s via tab replacement.
[2026/02/08 02:05:25.305] [WARN] [cnbc-id7luo] Detected 10 consecutive tiny segments (1092749 bytes). Capture pipeline appears dead.
[2026/02/08 02:05:28.460] [cnbc-id7luo] Tab replacement complete. New capture started with segment continuity.
[2026/02/08 02:05:28.460] [cnbc-id7luo] Recovered in 3.2s via tab replacement.
I tested on the same server / deleted container and volume between versions.
Tell me how I can help.
