Hmmm, updated and now can't get to admin page. I get an internal server error message. I've tried restarting the container, stack, and Docker.
I can not get this version to run. Tried to upgrade in place and got the errors. Did a clean install and got the errors:
Starting PrismCast...
Navigate to this URL:
http://prismcast:6080/vnc.html?host=prismcast&port=6080
Press Ctrl-C to exit
[2026/02/14 18:46:32.433] Using FFmpeg at: /usr/local/lib/node_modules/prismcast/node_modules/ffmpeg-for-homebridge/ffmpeg
[2026/02/14 18:46:32.435] Loaded 284 channels.
[2026/02/14 18:46:32.803] Chrome ready: Chrome/145.0.7632.75.
[2026/02/14 18:46:33.476] Capture system verified successfully.
[2026/02/14 18:46:33.605] PrismCast is now listening on 0.0.0.0:5589.
[2026/02/14 18:46:33.605] HDHomeRun emulation is now listening on 0.0.0.0:5004 (DeviceID: 10428300).
[2026/02/14 18:46:41.060] [ERROR] Unhandled error in request: text.replace is not a function.
[2026/02/14 18:46:41.061] GET / from 192.168.1.109 responded 500 in 18.026 ms.
[2026/02/14 18:46:45.249] [ERROR] Unhandled error in request: text.replace is not a function.
[2026/02/14 18:46:45.250] GET / from 192.168.1.109 responded 500 in 5.020 ms.
[2026/02/14 18:46:50.000] [ERROR] Unhandled error in request: text.replace is not a function.
[2026/02/14 18:46:50.000] GET / from 192.168.1.109 responded 500 in 3.950 ms.
I can access the novnc page just fine, just not the app home page. The app is down hard in this situation.
Yep...I see it. I'm working on it. Please hold off upgrading to v1.3.0 for a bit. v1.3.1 will be out shortly.
I believe (not sure) that this is the same problem with getting FS1 and 2 to work on fox.com. No matter what search term I put in, it either returns the first channel or the second channel in the grid.
Local Fox channel always works because it's the first channel in the grid I guess.
@daldana7296 and @mike_here v1.3.1 is out, give it a go.
As a test, I setup these 6 channels, using the included preset channels, only changing the provider on them to You Tube via the dropdown. Hit test on each one and verified they played in the chrome browser that PrismCast launched.
v1.3.1 should be a bit better for you...PrismCast better accounts for pacific/west coast variants now. Also, when PrismCast doesn't know or can't figure out what your local is, it'll properly fail now and log what the options are for you, so you can add it in as a user-defined channel and override what's built in.
Sorry about that!
No problem here also with v1.3.1. Thank you.
And @bnhf - give the new Sling TV integration a go. Curious to hear your thoughts.
Can you point me in the right direction for matching Sling channels in the grid guide. Can I use the callsign, or should I be looking for something else? I'm only subscribed to about a dozen premium movie channels...
Back up here too. Thanks!
If you go to the Channels tab in PrismCast and add a user-defined channel and click on the link for profile reference you'll see a good explanation for every profile type and how to figure out what the channel selector should be. For Sling:
slingLive (channel name)
Inspect a channel entry in the guide → find the
data-testidattribute starting withchannel-→ use the portion after that prefix. The name may differ from the logo shown (e.g., "FOX Sports 1" not "FS1"). For local affiliates (ABC, CBS, FOX, NBC), use the network name — PrismCast resolves the local station automatically.
v1.3.1 - In this build all channels appear in the m3u and brought into channels dvr from prismcast -- including all disabled channels.
I can't reproduce this. Disabled channels show up as disabled in Channels and reappear when enabled when I try. Can you give me a reproducible set of steps so I can see if I can recreate the behavior? Not to ask the obvious...but did you have Channels reload the playlist after enabling/disabling?
I just tried this, and both FS1 and FS2 worked for me both as custom channels (with FS1 and FS2 as "Channel Selectors", respectively) and using the default (preferred). You might try deleting the custom channel your using (that requires a "Channel Selector"), and just use the standard Fox as the source.
I've had this same situation in the earlier versions as well. I stopped trying to disable any channels in prismcast, because they would always come back. I've just disabled all the channels I don't receive in Channels DVR settings instead.
Color me impressed! Everything I've tried so far has worked brilliantly. This is really shaping up to be an amazing tool.
If you curl the playlist, are you seeing a different set of channels than what's showing as enabled in the WebUI?
@hjd,
Great project!
One question, when adding a channel, is there a way to specify the epg source (not a Gracenote entry)? I can add the FruitDeeplink lanes and they play fine, but to get any guide data, I have to add it's xml file in the Custom Channels settings. Doing this kills the guide data for the predefined channels.
Does this make sense?
Glad to hear it. I gave it a good beating from a robustness perspective...enjoy!
Great project!
Glad you're enjoying it.
One question, when adding a channel, is there a way to specify the epg source (not a Gracenote entry)? I can add the FruitDeeplink lanes and they play fine, but to get any guide data, I have to add its xml file in the Custom Channels settings. Doing this kills the guide data for the predefined channels.
Thanks for raising this — I think the friction here comes from how Channels handles guide data versus what PrismCast provides.
PrismCast’s role is to generate and serve the M3U playlist to Channels DVR and to provide access to those channels through the providers that it understands, and provide a way to extend it to new ones.. For most predefined channels, that includes a Gracenote station ID (with the exception of local affiliates, since those vary by region). For user-defined channels, you can assign a Gracenote station ID, leave it blank, or override the ID on any predefined channel.
PrismCast itself doesn’t provide or host EPG data. Guide data is entirely handled by Channels DVR based on the station IDs it receives.
At this point, I have no plans for PrismCast to act as its own EPG provider. PrismCast is a focused effort with a clear mission - tune most TVE/useful sources, most of the time, as easily and reliably as I can make it.
