Oddly enough, it was a Spectrum commercial that caused it to freeze up. I've got an hour and a half of guys talking about baseball while the words "Spectrum Business" are on the screen.
I just looked at doing that, but there are actually multiple commands used that don't work in Windows environments. Several have to do with "refreshing" Chrome itself, to keep it healthy. pkill appears to be the only one you're seeing, but others are likely failing behind the scenes.
It can be done of course, but it's not a straight swap one command for another to achieve the same functionality.
This is already on my radar and slated to be addressed more holistically in an upcoming release…appreciate folks raising it.
You could try upping shm_size to 2gb.
Otherwise, what are the specs on your Unraid host?
Getting inconsistent results with the Providers API /providers/yttv/channels?refresh=true
It's not returning all the channels that appear on the YTTV Live Guide and returns a different amount each time it runs.
Maybe it needs to wait for the page to fully load?
In particular it's missing these channels that are in the YTTV Live Guide
ESPN in 4K
FOX Sports Plus 4K
NBA TV in 4K
NBC Sports Bay Area Plus
NBC Sports California Plus
That hardware should be quite adequate. Although I primarily use a Mac Mini M4 for PrismCast (as I don't use it for much else), the container testing I've done has been on a 12th gen i3 running Docker in a Proxmox LXC -- and I haven't seen any stuttering.
Definitely try upping the shared memory setting, and there are others you could potentially play around with to allocate more resources to a container, but those would be changes that would apply just to you.
A chatbot could likely guide you through possibilities. Maybe other Unraid users as well, for ways to deal with containers that require significant resources in Unraid environments?
Stuttering? No -- not normal. There are numerous people using this project successfully on hardware platforms with lower specs than yours.
Maybe I'm comparing it to the LinkPi encoder output a little bit too much. And this is browser capture, so that could be what I'm seeing. And it's perfectly normal, possibly.
Stuttering isn’t normal. Would be helpful for me if you could post a real example BTW, so I can take a closer look. I, in general, have no plans to directly dive into Docker-specific challenges. If you want the best experience, I would encourage you to run PrismCast natively on macOS. It’s going to have the best performance characteristics - both due to Apple Silicon being quite capable for this sort of thing, and the ability for Chrome to use hardware acceleration.
Anecdotally - I would say that issues like you’re describing inevitably point toward resource issues - be that CPU or memory. @bnhf is the official PrismCast on Docker expert, not I though. :smile: You might want to run an experiment for yourself and simply shut everything you can down on the machine and substantially over-resource PrismCast and see what happens. If it works well, you can start to methodically adjust the variables until you discover a sweet spot, perhaps.
This is unrelated to shm_size though. Docker sets it by default at something like 64MB, we set it to 1gb in the compose, but 2gb is better for systems that need it. Have you tried making that change?
Just curious if this stuttering is happening when you are trying to capture at 1080? I run in a docker with an i5-10400 and when I capture at 720 high it’s fine but if I bump it up to 1080 high I get what I call super micro stuttering. Hard to explain it. Even at 1080 high it’s only using about 15-20% CPU. It feels less like a resource thing than a chrome thing. @bnhf is the container using chrome or chromium?
Just wanted to report this YouTube TV (auto) problem (using v1.52). I have it working now.
Yesterday I deleted all my custom new and overridden channels, set my Provider to FoxOne and YTTV and assigned all channels to YTTV. I then deleted all channels I don't receive and went through the rest of the predefined channels to set them up.
With the Paramount channel using the default profile YouTube TV (auto), it kept failing like it couldn't find the channel selector Paramount, even though it's there. I could see it repeatedly opening a browser tab to the live guide and then closing the tab.
Once I edited the channel to change the profile to youtubeTV, it started working.
[2026/03/02 16:05:35.749] Provider filter updated: foxcom, yttv.
[2026/03/02 16:14:48.736] Bulk assign to 'yttv': 138 of 212 channels affected.
[2026/03/03 00:09:17.066] [ERROR] [paramountp-qwntnh] Stream setup failed for https://tv.youtube.com/live: Waiting failed: 11000ms exceeded.
[2026/03/03 00:09:17.067] GET /hls/paramountp/stream.m3u8 from 192.168.1.4 responded 500 in 12461.358 ms.
[2026/03/03 00:09:27.328] [oxygenp-22drc0] Stream ended after 1m 2s.
[2026/03/03 00:09:29.634] [ERROR] [paramountp-40qf1y] Stream setup failed for https://tv.youtube.com/live: Waiting failed: 11000ms exceeded.
[2026/03/03 00:09:29.636] GET /hls/paramountp/stream.m3u8 from 192.168.1.4 responded 500 in 12466.586 ms.
[2026/03/03 00:09:46.154] [ERROR] [paramountp-1ks3p7] Stream setup failed for https://tv.youtube.com/live: Waiting failed: 11000ms exceeded.
[2026/03/03 00:09:46.295] GET /hls/paramountp/stream.m3u8 from 192.168.1.4 responded 500 in 1006.061 ms.
[2026/03/03 00:10:02.402] [ERROR] [paramountp-5y4vuh] Stream setup failed for https://tv.youtube.com/live: Waiting failed: 11000ms exceeded.
[2026/03/03 00:10:02.429] GET /hls/paramountp/stream.m3u8 from 192.168.1.4 responded 500 in 803.294 ms.
[2026/03/03 00:10:16.660] [ERROR] [paramountp-3ffml0] Stream setup failed for https://tv.youtube.com/live: Waiting failed: 11000ms exceeded.
[2026/03/03 00:10:16.663] GET /hls/paramountp/stream.m3u8 from 192.168.1.4 responded 500 in 12640.424 ms.
[2026/03/03 00:12:12.378] User channel 'paramountp' updated.
[2026/03/03 00:12:33.032] [paramountp-jzt1aq] Streaming Paramount (Pacific) (youtubeTV, FFmpeg). Tuned in 2.5s (direct).
[2026/03/03 00:13:57.352] [paramountp-jzt1aq] Stream ended after 1m 27s.
Thinking it may have been a fluke, today I changed the Profile back to Autodetect and it failed again.
[2026/03/03 17:47:12.698] Provider for Paramount (Pacific) changed to YouTube TV.
[2026/03/03 17:49:53.677] [ERROR] [paramountp-vykjcu] Stream setup failed for https://tv.youtube.com/live: Waiting failed: 11000ms exceeded.
[2026/03/03 17:49:53.677] GET /hls/paramountp/stream.m3u8 from 192.168.1.8 responded 500 in 14405.254 ms.
[2026/03/03 17:50:08.276] [ERROR] [paramountp-7nmif7] Stream setup failed for https://tv.youtube.com/live: Waiting failed: 11000ms exceeded.
[2026/03/03 17:50:08.277] GET /hls/paramountp/stream.m3u8 from 192.168.1.8 responded 500 in 14548.647 ms.
Let me know if there's anything else you want me to try to make it work.
Chrome.
Does yours also smooth out at 720 high? If so I don’t think it’s an unraid thing.
Try changing the PrismCast Config bitrate.
For 1080p High I'm setting it to 5 Mbps which results in a 10 Mbps stream.
I'm going to drop the config setting to 4 Mbps to get an 8 Mbps stream.
Lower quality than the TVE streams too. A bit softer (loss of detail). Even using the default bitrate at 1080p High, which results in a 25 Mbps stream.
While your money tree is still growing, just buy a Mac Mini and be done with it :laughing:
Got this setup and think its working pretty well. I would be interested if this could be setup for the Masters next month to get the live stream off their website, masters.com. Practice rounds start Tuesday April 7th. I believe it the plan is for the coverage to be a mixture of CBS, ESPN, Paramount+ and Amazon prime video. What a mess. One feed from masters.com would be ideal, without all the crap those stations pump in.
I'm running this exact cpu on ubuntu server, NVMe SSD, but only 32GB DDR4. I installed the docker using olivetin. It works fine for me. no stuttering. no settings modifications for me
Hey there. Thanks @hjd for the great work and effort put into PrismCast!
I've managed to get some hardware acceleration working in a Docker container by building a new image based off linuxserver/docker-chrome. It's brought down CPU usage on an old mini PC with an i7-6700 significantly for me.
I don't have much time available to dive in deeper, but thought maybe someone else could pick it up and run with it. The container repo can be found here with a sample Docker compose in the readme: GitHub - ajvolin/prismcast-hwa · GitHub
For anyone looking to play with it - this container is fundamentally different than the official PrismCast container. Only three of the environment variables are retained:
PRISMCAST_DATA_DIR
PRISMCAST_LOG_FILE
PORT
The container inherits environment variables from the docker-chrome image, and in turn its source: GitHub - linuxserver/docker-baseimage-selkies: Base Images for remote web based Linux desktops using Selkies for many popular distros. · GitHub
FINALLY
GPU support in Prismcast. You did it!! I'll give it a whirl later in the week. This looks good
I've actually been down this road before with the linuxserver Chrome image. In fact, I created a version of cc4c that used it. What they did is implement a hardware accelerated version of Xvfb, and when you're actively using noVNC, you have the appearance of improved performance.
Hopefully you've found something I didn't, but I've also been able to get chrome://gpu to look just like what you posted, but when you look at GPU usage on the host you'll see Chrome isn't using it. With the linuxserver image, you'll see Xvfb will use it, but that's really only a factor when you're using noVNC to look-in.
I hope I'm wrong -- but I just wanted to let you know this approach has been previously explored.
If you could install intel-gpu-tools on your host, and post your intel_gpu_top results that would help confirm one-way-or-the-other whether Chrome is using the GPU in your container.
Here's a bit of the backstory on GitHub:
