It started on Docker, but I moved to an LXC to see if that solved it based on (if I'm in the right conversation) the above. Both hosted on proxmox with intel hardware. The LXC is all that remains.
I'm probably not going to be able to help you. My installation is native Mac.
The screenshot you show tells me you are not signed into your provider thus nothing will probably work.
Here's a quick synopsis of the workflow that I used:
After installing PrismCast, I went to the PrismCast server page using DuckDuckGo.
Go to Channels tab. Pick a channel and select the authentication icon (half box with arrow right). This will open a Chrome window that will allow you to authenticate that channel with your TV provider. I then go back to DDG and hit the Done button which will close the Chrome window. Do not manually close the Chrome window.
You will have to authenticate for all your channels. I normally authenticate using the expected channel’s website when available since I use DTVS which only allows 1 stream.
Hope this helps you. There are more knowledgeable people that are familiar with a setup as you have on this site than I am.
The part between prismcast and YTTV does seem to work despite that warning, and allowing VLC to stream it. It just won't work with Plex.
Pressing test (Prismcast on the left, VNC on the right):
I was going to post it playing in VLC with teh HLS link to Prismcast, but I can only do one image per post as a new user. I was going to put it in another comment following this, but this will seemingly be my last reply because I can't post more than 3 comments in the same thread for the same reason.
Have you completed Step #3. It ain’t gonna work til you authenticate.
Quick Start with Plex
PrismCast includes builtin HDHomeRun emulation, allowing Plex to discover it as a network tuner.
  1. Start PrismCast — HDHomeRun emulation starts automatically on port 5004
  2. Add to Plex:
  • Go to Settings → Live TV & DVR → Set Up Plex DVR
  • Enter your PrismCast server address with the HDHR port: <your-prismcast-host>:5004
  • Plex will detect PrismCast as an HDHomeRun tuner and import available channels
  1. Authenticate — If channels require TV provider login, go to the PrismCast web interface at http://localhost:5589 and use the Channels tab to log in
This might help or give you some ideas.
UPDATE: I was able to use AI to fix the problem. After laborious trouble-shooting, it turned out to be a bad profile. The AI had me rename the folder, and a new one got created. All seems to be working now. Leaving the below in place in case it helps anyone else, but I don't need any further help here (at least at the moment!)
I had had my Chrome frozen at 148 to allow Prismcast to work (couldn't get it working otherwise) around version 1.11. Tonight I tried letting it update (now on 159) to use Charon (which works now). Prismcast went back to its old "trick" of refusing to start up. I updated Prismcast to 1.14.0 to see if that would fix it, but it didn't. Logs:
[2026/11/15 02:18:39.536 AM] Starting PrismCast v1.14.0 with configuration:
[2026/11/15 02:18:39.537 AM]   Configuration file: C:\Users\Lois\.prismcast\config.json
[2026/11/15 02:18:39.537 AM]   Chrome profile: C:\Users\Lois\.prismcast\chromedata
[2026/11/15 02:18:39.537 AM]   Server port: 5589
[2026/11/15 02:18:39.537 AM]   Quality preset: 720p-high (1280×720)
[2026/11/15 02:18:39.537 AM]   Capture codecs: h264, hevc
[2026/11/15 02:18:39.537 AM]   Video bitrate: 8000000
[2026/11/15 02:18:39.537 AM]   Max retries: 6
[2026/11/15 02:18:39.537 AM]   Max concurrent streams: 10
[2026/11/15 02:18:39.537 AM]   Circuit breaker threshold: 10 failures in 5 minutes
[2026/11/15 02:18:39.537 AM]   Browser relaunch governor: trips at 3 failures in 5 minutes, 2 minute health hold
[2026/11/15 02:18:39.537 AM]   Chrome executable: autodetect
[2026/11/15 02:18:39.537 AM]   HLS segment duration: 2s, max segments: 10
[2026/11/15 02:18:39.537 AM]   HDHomeRun emulation: disabled
[2026/11/15 02:18:39.558 AM] Using FFmpeg at: C:\ProgramData\channelsdvr\latest\ffmpeg.exe.
[2026/11/15 02:18:39.576 AM] Loaded 1256 channels (87 user, 1169 predefined).
[2026/11/15 02:18:39.577 AM] Loaded health state for 2 channels and 1 domains.
[2026/11/15 02:18:39.578 AM] Loaded persisted channel lineups for 1 provider.
[2026/11/15 02:18:49.413 AM] e[31m[ERROR] Failed to launch browser: The capture extension did not become ready within 5000 ms.e[39m
[2026/11/15 02:18:50.249 AM] e[31m[ERROR] Failed to initialize browser during startup: The capture extension did not become ready within 5000 ms.e[39m
[2026/11/15 02:18:50.250 AM] e[31m[ERROR] Fatal startup error occurred. { error: 'The capture extension did not become ready within 5000 ms' }e[39m
What shows on-screen when I start Prismcast:
The chrome window starts with several tabs open, then quickly shuts itself down.
Dashboard says "browser disconnected."
Task manager does not report any Chrome instances running.
Environment:
Windows 11
Prismcast installed via npm
Additional info:
I used a screen capture to see what other info I could get. I quickly clicked on one of the many tabs Prismcast had opened in Chrome and saw:
followed by:
I Googled err_blocked_by_client, and it said an adblocker could be blocking it. I don't have any adblockers installed, but I disabled the 3 extensions that were there, but it made no difference. Another suggestion I found was to clear cache. That didn't help either.
I'd really like to be able to use both Prismcast and Charon, since each does things the other doesn't, but the only way Charon will work is with a newer version of Chrome, and the only way Prismcast will work (at least for me) is with an older one.
I had an instance of prismcast running for a while, everything was good. One of the latest updates, either docker, or prismcast broke it. While testing with novnc, I can see the chrome browser bar only, but it's not maximizing. I've tried ctrl +n to open a new window, I tried expanding the window, but nothing, it just stays just the bar only. My config has the proper screen size. I have tried the novnc config. Nothing works. Any thoughts?
This reads like an issue I fixed about a month ago, but it doesn't look like a new build has been done incorporating it. You can either wait for that to happen, or try bnhf/prismcast:latest which should fix this in the meantime.
As a bonus, if you've configured your container to use an iGPU, you should see chrome://gpu report hardware accelerated encoding and decoding. :slight_smile:
Since Chrome auto updated to Version 158.0.8127.37 PrismCast no longer works. When I try to tune to a station from CDVR, the Chrome windows continuously opens and closes a tab trying to select the channel. When I look at the log it states that in can't find the channel. When I open the same Sling guide URL in Chrome I can scroll down, select and play the same channel it couldn't find.
I'm using PrismCast v1.14.0 instated on macOS using home-brew.
Here is the log from PrimCast:
[2026/11/20 08:54:38.271 PM] GET /hls/starz/stream.m3u8 from 127.0.0.1 responded 500 in 11211.271 ms.
[2026/11/20 08:54:48.254 PM] [WARN] [starz-ckb9e5] Channel "STARZ" not found in Sling TV guide. Create a user-defined channel with one of the names below as the Channel Selector and https://watch.sling.com/dashboard/grid_guide/grid_guide_a_z as the URL. Available channels (uncovered (135 of 163)): beyond paranormal, big 12 studios, big a anime, billiard tv, bingetv, bizarre foods with andrew zimmern, bloodline detectives, bold and the beautiful, bon appetit, boot, bounce xl, bowling tv, bravo vault, buzzr, car chase, carnegie hall + avod, cartoon network & adult swim, caught in providence, caught on video, celebrity name game, celebrity poker tour, charge!, charity tv, chasing criminals, cheaters, cheddar news, christmas plus, cine club, classic car auctions by history, classic doctor who, classic yule log, cold case files, combat war channel, comedy dynamics, comet, como dice el dicho, complex tv, confess by nosey, documentary+, dog the bounty hunter, dog whisperer, dogtv sneak peek, dove channel, dr. g medical examiner, draftkings network, dronetv, dubai tv, duck dynasty, earth day 365, law & crime rewind, lawless, lb2, lifetime holiday movie favorites, lifetime movie network, lifetime preview, livenow from fox, living with evil, local now, lol! network, lone star classics, manorama news, martha stewart channel, matched married meet, maverick black cinema, mayday: air disaster, mea tv, meateater, metv, mgm+, mgm+ drive-in, mgm+ hits, mgm+ marquee, midnight pulp, midsomer murders, military heroes, million dollar listing vault, miramax movie channel, modern innovations by history, modern marvels, modern yule log, most haunted, moviesphere by lionsgate, moviesphere by lionsgate on demand, moviesphere gold, mr bean live action, msg sportszone, mysterious worlds, outlaw, outside tv, outside tv features, overtime, pac films, padre pio, palestine live, pam grier's soul flix, paramount+ with showtime, paramount+ with showtime west, paranormal chronicles, paranormal files channel, silent witness & new tricks, sky news arabia, slightly off ifc, sling scapes, sling scapes 2, sling sneak peek, snl vault, sony kal, sparktv: light & love, speedvision, sportsgrid, stadium, starlink info, starz kids & family, stash tv black stories, stash tv screams & scares, stingray remember the '80s, stingray smooth jazz, stingray spa, stingray today’s latin pop, stories by amc, strangely addicting by wb tv, supermarket sweep, sweet escapes, swerve combat, tastemade, the sherlock holmes channel, the three stooges+, the tmz channel, the walking dead universe, thearchive, tiktok radio, times now navbharat, times play, tiny house nation, todo cine.
[2026/11/20 08:54:48.256 PM] [ERROR] [starz-ckb9e5] Stream setup failed for https://watch.sling.com/dashboard/grid_guide/grid_guide_a_z: Channel selection failed: Could not find channel STARZ in Sling TV guide grid.
[2026/11/20 08:54:48.278 PM] [starz-ckb9e5] Stream ended after 9s (setup failed).
[2026/11/20 08:54:48.279 PM] GET /hls/starz/stream.m3u8 from 127.0.0.1 responded 500 in 8908.364 ms.
[2026/11/20 08:54:55.340 PM] [WARN] [starz-2imlbz] Channel selection failed because the guide did not render: Sling TV guide grid did not load.. Reloading the page and retrying once.
[2026/11/20 08:55:00.613 PM] [ERROR] [starz-2imlbz] Stream setup failed for https://watch.sling.com/dashboard/grid_guide/grid_guide_a_z: Channel selection failed: Sling TV guide grid did not load.
[2026/11/20 08:55:00.630 PM] [starz-2imlbz] Stream ended after 11s (setup failed).
[2026/11/20 08:55:00.631 PM] GET /hls/starz/stream.m3u8 from 127.0.0.1 responded 500 in 11206.236 ms.
I ran into the same thing. Some time back I had frozen my Chrome to let Prismcast work, but I finally needed to unfreeze & update. I also updated Prismcast to 1.14. in hopes of no longer needing to freeze Chrome.
After the latest update, I did the following (this is in Windows 11, so it is probably different for other OS's, but with luck there's something similar that works:
  1. re-froze Chrome (I'm no longer convinced this is strictly necessary, but I'm leaving it frozen for now because the process is time-consuming):
    a. Go into Services, find anything that looks like Google Updater and change its status to "disabled."
    b. Uninstall the most recent version of Chrome
    c. Get an earlier version of Chrome: Older versions of Google Chrome (Windows) | Uptodown. This time I went back a couple weeks. Install it.
    d. Find this: C:\Program Files (x86)\Google\GoogleUpdater[version number]. Rename updater.ext to something like updater.exeDONOTUSE. If there are more than one version folder, do the same thing in all of them. Also if there is a folder C:\Program Files (x86)\Google\Update, rename the updater.exe there too.
    e. reboot (not sure this is strictly necessary, but why not - might also be good to do right after uninstalling the new Chrome)
Retry Prismcast. If it works again, great. If not, continue to step 2, which an AI helped me identify and figure out.
  1. a. stop Prismcast
    b. Locate your chrome profile that is just for Prismcast. In Windows, it is here:
    C:\Users\username.prismcast\chromedata
    b. Delete (or rename for safety, but it's a big file) the chromedata folder. It will be recreated.
    c. restart Chrome & prismcast
    d. re-initialize your services inside Prismcast, since deleting the profile wiped those out.
  2. Retry everything - in my case, it worked again. It may be the case that only one of the downgrading & freezing Chrome or wiping the pismcast profile needs to be done, but I did both. I'll have to decide if I want to let Chrome update itself again.
Is anyone else having issues with PrismCast with Chrome Version 158. PrismCast no longer able to find any of my Sling TV premium/add-on channels. When tuning to any of those channels from CDVR, the PrismCast Chrome window continuously opens and closes a tab trying to select the channel until it times out.
I was able to get it working by re-authenticating in PrismCast but then Chrome auto updated to another minor release of version 158. Chrome is also reporting the following error:
I'm using PrismCast v1.14.0 instated on macOS using home-brew on M4 Mac Mini. Is the only solution to restore PrismCast functionality is to install an older version of Chrome and disable auto update?
That's a warning, not an error. :rismcast uses a plugin, which my Chrome displays in its own tab:
chrome-extension://jjndjgheafjngoipoacpjgeicjeomjli/options.html#55200
Is Sling the only thing not working? If you have other sources that work, the problem you have could be different from the one I had & solved in my Windows system after a Chrome update. Scroll up and look for my post about the issue I had & fixed. It involves deleting the Chrome profile stored in Prismcast. I did it along with a slight rollback & freezing of Chrome, but I think it's most likely that the profile was the main culprit and I didn't need the freeze & rollback. I haven't tested that yet by allowing an update, however.
I am having the same issue. PrismCast 1.14.0 installed through HomeBrew, also on an M4 Mac Mini. After Chrome updated to version 158, I can't capture anything. I mostly use it for MSG networks through DAZN, and I am getting an error regarding DRM. I threw away the chromedata folder and restarted PrismCast, but that didn't help. Will probably try rolling back Chrome next, but wanted to add that the issue seems more widespread than simply the Sling channels.
The challenge with PrismCast is that the update tempo doesn't really match what's required for a project like this. I submitted several small changes, as did another developer, more than a month ago and none have been integrated into a new build.
At this point, for anyone that's not exclusively tied to the MacOS environment, I'd suggest the FastChannels Built-In Bridge for Docker users and Charon for Windows users.
If you're MacOS only, there really aren't any alternatives -- but for Docker and Windows users at least, there are other projects in more active development.
Yep, exactly. I'm not having any issues with 1.11.1 and chrome 158 on Windows, but the real problem with this project is that it's basically abandonware at this point. When it stops working with the latest Chrome update I'll switch to something else.
Really a sad situation because it's a fairly easy way to install and handle these channels, probably should just be forked off and let you run with it.
Just for clarification: I run Channels and PrismCast natively in macOS, but everything else related to Channels (including FastChannels) runs via Docker. Thus far PrismCast is still working for me, but do I understand correctly that FC's Built-In Bridge would be an option if that changes?
I have FastChannels running on my Mac using Docker. I was using PrismCast as my bridge, since I do not have any of the other hardware and all of that seems even more complicated for someone like me who
a). Doesn't fully understand how all of this works (even though I'm trying).
b). Only needs to record at most a single channel at a time, because I've gotten everything else to work via some other workaround.
If I dump Prismcast, because of its abandonware status, what is the best/easiest/cheapest option for somebody like me as a bridge?
FC has built in capture now, I replaced Prism with it myself.
After going through the documentation for FC, I see that now.
Unfortunately, it is not yet available for ARM based Macs.
I will see if I can get PrismCast working again with an older version of Chrome in the interim, then I will look to switch once FC's capture becomes available for my setup.
Thanks for the info.
I'm having a similar problem to what others have described above where PrismCast can't find the channel and the tab keeps opening and closing until it gives up. If I go into the noVNC session and open Chrome and go to tv.youtube.com/live, it shows me a list of 6 channels and I can scroll for the rest. For whatever reason. PrismCast doesn't appear to be able to actually scroll down so it can only tune the 6 channels it sees on that page.
This is not a fix for everyone but since I only need a few channels, here is what I did. I changed the view in YouTube TV to custom, and created a custom view with just the 6 channels I care most about. In the PrismCast config, I only have those 6 channels visible.
PrismCast can successfully record on any of those channels now. Not an ideal fix but it works for me. I think I saw someone say that another app can do something similar to PrismCast? Is that FastChannels? Or am I misunderstanding.
Thanks. I wouldn't call this a fix but at least for me it works for just 6 channels.
