Like the app, playback is smooth and channels change fast. First, what button takes you back to the previous channel? Second, is there a way to pull up the guide without stopping the video? I see you can pull up whats on now.
Double click the play/pause button.
Yes you can click down to view favorited channels. That’s the only way to switch channels inside the player.
Thanks, Hopefully in the future there will be a way to pull up a full guide without stopping the Video. The Fire remote has long press which makes a lot more commands available
