I have a new Fire Cube I'm trying to setup for travel. For some reason it won't find my Channels server using Tailscale (through my phone's hotspot), even though the phone itself will find the server as will my Ipad when connected to my phone's hotspot. It keeps giving the no server found message after typing in the IP address.
In the back of my mind I think I had a problem before at home using port forwarding because the hotspot was on the same subnet mask as my home network. If that's the case, I have no explanation for why my iPad would work connected to the same hotspot. I've also tried turning off WPA3, just in case, to no effect.
Ideas? And yes I've double checked the IP address and tried it multiple times. I even setup a new IP address through Tailscale for the Channels server.
Edit: It was some sort of weird conflict being in proximity to my home network. Walking a block or so from my house, where I was out of range of the home network, and everything worked fine.
