Kodi Add-on
I tested only with OTA.
Can you email support with the kodi logs and also submit dvr server diagnostics
I will do what I can. I don't have OTA. Is that HD Homerun?
I will be back in a couple hours but I can post the DVR diagnostics and maybe the kodi logs if I can figure out how in the next few minutes. Definitely will when I get back later. Thanks again.
Logs sent.
OTA works, but TVE does not. (in my testing)
Thanks. Bug confirmed. Trying to find a fix.
Which OTA device? HD Homerun?
I tried Docker - Pluto and Stirr, also PBS and Plex channels with no luck. Good to see ota is working and the skip forward during time shifting is also fixed and working great.
A release notes topic was created for the Kodi Add On. All notes will be published there from now on. You can go follow it here:
I tried this on 64 Bit Windows 10 on a Clean Install of KODI and the plugin crashes KODI instantly... as soon as I try to navigate within KODI.
2021-09-29 18:19:13.453 T:4116 INFO : CActiveAESink::OpenSink - initialize sink
2021-09-29 18:19:21.400 T:16900 INFO : CAddonMgr::ADDON::CAddonMgr::FindAddon: pvr.channelsdvr v2021.09.29.2243 installed
2021-09-29 18:19:21.451 T:5080 INFO : AddOnLog: pvr.channelsdvr: Initializing CDVRAddon
2021-09-29 18:19:21.471 T:5080 INFO : AddOnLog: pvr.channelsdvr: Using addon path: C:\Users\epere\AppData\Roaming\Kodi\userdata\addon_data\pvr.channelsdvr
2021-09-29 18:19:21.472 T:5080 INFO : AddOnLog: pvr.channelsdvr: Starting discovery
2021-09-29 18:19:25.473 T:5080 INFO : AddOnLog: pvr.channelsdvr: Discovery failed: timed out during discovery
2021-09-29 18:19:25.475 T:5080 INFO : PVR Manager: Starting
2021-09-29 18:19:25.481 T:3988 ERROR : GetChannels: Add-on 'Channels DVR:unavailable' returned an error: server error
2021-09-29 18:19:25.481 T:3988 ERROR : PVR::CPVRClients::GetChannels: PVR client 'Channels DVR:unavailable' returned an error: server error
2021-09-29 18:19:25.502 T:3988 INFO : AddOnLog: peripheral.joystick: Disabling joystick interface "directinput"
2021-09-29 18:19:25.502 T:3988 INFO : AddOnLog: peripheral.joystick: Disabling joystick interface "xinput"
What if you set the IP under addon settings?
New beta is recording TVE source. Thanks.
AS soon as I try to move around KODI to set IP KODI Crashes... cannot even get to the addon. I have to uninstall KODI and reinstall KODI works fine without addon.
My experience is when it crashes because it is on automatic, restart Kodi a couple times and eventually it won't crash right away. After a while it will crash once again. Setting it to your server ip address, rather than automatic, will stop the crashing.
Edit...I just got my first startup crash with the auto setting off and my ip address entered. Again, I was able to restart it a couple times and it will work.
Thanks ... but there is something wrong with the code that causes it to crash and needs to be looked at.
Yes, HDHomeRun Primes
When it crashes, it seems to do it as it is loading the guide info.
Hi
For me recordings work ok, but kodi do not play any recordings.
Recordings play just fine on dedicated channels dvr app.
Kodi 19.1 running on nvidia shield.
Channels dvr server on Windows server 2019
Thank you
Need the kodi log to investigate.
Ok
Kodi log
https://paste.kodi.tv/ififizapoq
Thank you
Tried to play 2 recordings, just a black screen.
Both recordings play fine on dedicated app on nvidia shield
Latest build v2021.10.01.0047 with crash fixes:
