I can't seem to get v2021.10.05.0314 to download from the repository.
What did you do?
What did you expect would happen?
What actually happened?
Not sure if that is to me, but I will answer.
I originally installed from the repository for the add-on. I expected an auto update (auto update is enabled), when that didn't happen, I clicked on the 'versions' button, and only saw the previous version (v2021.10.02.xxxx). I restarted Kodi, same thing.
I just checked the PC, and it did update, so it appears that only the Shield didn't update. I will check again and see if anything has changed.
Did you right click on the repo and select Update?
I had not, and that did fix it. I have never had to do that before. is that because it's in beta?
EDIT: Quoting doesn't seem to be working anymore on the forum. This is the second time I have quoted something this morning, and when I click save, it isn't in the post, but the post says it has 1 edit (which I didn't do).
Quote check...
I think it is if you quote the entire post and it is the previous post.
No love for timeshifting live active recordings? All the other devices are doing it.
The notification fix seems to be working. Thanks again for the add-on. It supplements well with PlexKodiConnect add-on.
I have noticed that. If you 100 percent want it to quote, just highlight the entire post except one punctuation.
I made it so you can quote the full thing now.
I would like to see manual recording options to include start time, end time, and channel...please...when you get a chance.
Time/date/channel–based recordings have yet to even make their way to the Channels DVR UI. I would think such a feature would make its way to the DVR web UI and clients before making an appearance in the Kodi PVR client.
If you are interested in this, you can find instructions here for how to do this on your own:
Just curious, do epg based recordings work for you? Manual recording options would be cool too but I haven't been able to get epg based recordings to work either and wanted to make sure I'm not doing something wrong?
You need to update your dvr server to prerelease
Is it possible to have the new Virtual Channels in ChannelsDVR work with this addon? I can see the channels in the guide - but none of them play.
I find that the ChannelsDVR client doesn't seem to like 4k HDR content when it is added from my Virtual Channels. I wondered if using Kodi - which does seem to support a lot of content types - might be a good work around for reliable playback hence using this addon.
Virtual Channels don't work on the web player either.
I am actually surprised this add-on made it this far.
No time shift during active recordings is the most important feature missing but virtual channels would be welcomed for sure.
I can't really think of anything else I truly miss from the supported apps compared to this Kodi implementation.
What happens right now if you try to watch something that's recording?
Hi
Is it possible to have this amazing plugin for kodi on Apple TV ?
Thank you
It is not possible to run on appletv or Xbox due to how those platforms restrict addons.
That’s strange.
I can run any addon, official or not official on kodi for Apple TV.
Excepting those that require widevine that I think is not the case. Or is it?
Thank you anyway. Great work.
