@tmm1
Probably nothing much!
More little things …
Two things I miss already from the Android TV “Live Channels” app.
1 - When you run it, it automagically comes up on the last channel you were watching, no menus, straight in …
Could this be an alternate “mode” for your app? A toggle in setup/prefs so that those who want it this way can have it?
2 - In “Live Channels”, hitting “Up” or “Down” just takes you to the previous/next channel, one key press. Or in fact keep hitting up or down keys to get to the channel you want, when you stop it, it then selects that channel.
I know in your App I can hit “Down” and then scroll Left or Right and then hit “Ok” to select a new channel, but this is many more key strokes (at least 3?) and not necessarily as intuitive for “less technical” users like my Mother
Could this be also an alternate “mode” for your app? A toggle in setup/prefs so those who want it this way can have it?
Would need to (also) work on Favourites so it just cycled through the channels in the order they have been arranged, and when it got to “last” channel it just cycled around to the first, and obviously showing you with the banner which channel you are on so you can stop hitting up/down and let it select, if that makes sense?
These two features combined would make it pretty much perfect!
Obviously would also be interested in trying Channels DVR if it ever comes to Australia as well as looking to replace my DVR. I have an IceTV subscription for that which supplies guide data.
Hope you don’t mind me barging in here as a noob with all these ideas!
StephenH
