Same issue here, I will try the beta
Just had issue with beta, logs submitted
Happened just now, submitted logs
sorry, was on last beta, just updated, I'll post if problems
Had the problem this am, live TV, submitted log
Just had the problem again, submitted log. Any ETA on a fix?
Just happened again, live OTA, logs submitted. ETA for a fix?? Thanks
OK, changed to linear(60FPS), I'll report back. Thanks
Just happened again, submitted logs
Not sure it fixed it 100%, see my April 28 post above. Have not heard if it is related but I did submit the logs.
Still happening on Test Flight for me.
Did you submit diagnostics
multiple times
@psternklar got the diagnostics. Can you describe in detail what you experienced? What channel you were watching and then how long it took, and what happened?
@Eric I was watching 6 or 13 (do not remember). The sound was about 2 seconds behind the video. Started after the show was on for over 1 hour. Similar to previously.
@psternklar ah, so it sounds like you're suffering from a different issue from everyone else in the thread (which as you can see from the title is about video being slow).
Edit: I've split this into a separate post because it's a separate issue
