Live TV unintended paused, connection still active
Hello,
with the official Android version (v4.9.0) but also the latest beta (v2025.04.23.2017) we have the problem that the picture just stops as if someone presses pause, but nobody does.
You can then end the pause by pressing the remote control and it continues to play or jump to live TV.
I can also fast forward completely to live TV, there is no gap. But it just pauses.
The strange thing is that the connection is active the whole time, which is also confirmed by the admin overview. Here is also buf=0% and drop=0%
I have already submitted the diagnosis
P.S.: By the way, if you show the stats in the latest beta, the picture runs for 1-2 seconds and then freezes completely.
What else could be causing this?
Ping @tmm1 @maddox
I also occasionally get an unforced pause. I think it may run out of cache (audio). Looking at the stats, I can see less than 200ms available much of the time. Sometimes it will restart after the pause without me doing anything, other times I just rewind once.
Also, if you have added any extra storage memory to your device, it can cause pauses to occur. I had to find very fast memory for my Firestick 4k Max, otherwise it was unusable.
