even more frustration...web UI works, fire tv is frozen. i set up a recording and tried to watch the recording, when doing that both web UI and fire tv are frozen.
still nothing in the log that looks out of the ordinary...
2020/01/06 21:41:15 [TNR] Opened connection to LOCAST-803 for ch5905 KTLADT3 [transcode=none]
2020/01/06 21:41:49 [TNR] Sharing existing connection to LOCAST-803 for ch5905 KTLADT3 (clients=2, len=0)
2020/01/06 21:41:51 [HLS] Probed live stream in 1.8416681s: h264 704x480 5242880bps
2020/01/06 21:41:51 [HLS] Starting transcoder for channel 5905 from 192.168.88.70 (encoder=h264_mf, resolution=, deinterlacer=blend, bitrate=10000)
[h264_mf @ 00000000006fe880] stream format change
[mpegts @ 000000000061bd40] DTS 66000 < 72000 out of order
2020/01/06 21:41:58 [HLS] Stopping transcoder session ch5905-dANY-ip192.168.88.70 (out: 6.281311s, finished: false)
2020/01/06 21:42:38 [DVR] Starting job 1578373020-ch5905 Court TV Trial Coverage on ch=[5905]
2020/01/06 21:42:38 [DVR] Waiting 4h44m21.4268556s until next job 1578392820-35 Mork & Mindy
2020/01/06 21:42:38 [TNR] Sharing existing connection to LOCAST-803 for ch5905 KTLADT3 (clients=2, len=0)
2020/01/06 21:42:38 [DVR] Recording for job 1578373020-ch5905 from LOCAST-803 ch5905 into "TV\Court TV Trial Coverage\Court TV Trial Coverage 2019-09-23 2020-01-06-2142.mpg" for 2h20m21.4268556s
2020/01/06 21:42:38 [DVR] Refreshing metadata for Court TV Trial Coverage (17423365)
2020/01/06 21:42:39 [IDX] Generating video index for job 1578373020-ch5905
2020/01/06 21:45:56 [TNR] Sharing existing connection to LOCAST-803 for ch5905 KTLADT3 (clients=2, len=0)
2020/01/06 21:45:59 [HLS] Probe failed for live stream after 3.4049313s and 0 bytes
2020/01/06 21:45:59 [HLS] Starting transcoder for channel 5905 from 192.168.88.70 (encoder=h264_mf, resolution=, deinterlacer=blend, bitrate=10000)
[h264_mf @ 0000000002b32700] stream format change
[mpegts @ 000000000061bd40] DTS 8590003592 < 8590018592 out of order
2020/01/06 21:46:04 [HLS] Stopping transcoder session ch5905-dANY-ip192.168.88.70 (out: 5.333311s, finished: false)
