Thanks, that installed 2020.05.04.2052. I'll let you know how it goes!
the update did not stop the looping behavior.
Can you click Help > Submit Diagnostics from the dvr web UI, while the player is running and you notice the issue.
Just happened now, submitted logs: 1c4943a0-57f6-41c1-9cf9-ad7188728485
I just noticed that this happens with the web client as well as the Fire TV stick, so whatever it is, it's on the server side, or the stream itself.
I thought this had already been tracked back to errors in the original streams as sent from the networks' sites; the looping was because of issues with the playlist/segments and time stamp issues.
Is there evidence that the root cause is something else?
Never saw that analysis. Can you link it here?
