I have a subscription through Philo via TV Anywhere which includes the Hallmark channel and Hallmark Movies channel. For the past few days when selecting either channel all we get is a message....! get:https://crownmediaingest.akamaized.net/ with a long string URL which I won't type out. This is occurring on several Android devices and both the Channels DVR and beta versions apps. If I go to the Philo app both channels work fine.
Click and hold on the Check for Update button
That worked. Thanks tmm1! My wife will be happy now. I would never guessed that the update option had to be held down to force the update. Interesting!
Holding gets the latest (beta) release, while normal clicking checks for the latest production release. Now that you’re on beta, once the production version exceeds your current version automatic updates will resume.
Thanks for letting me know.
Updated to latest versions, Hallmark Channel and Hallmark MM still are not working.
Go into your TVE source, edit it, and rescan those specific channels. will work fine.
on my apple tv in settings i do not see a check for update button.
where would it be?
