Project: M3U8 Stream Inspector
I've developed a set of simple, interactive command-line scripts to help you quickly inspect HLS (.m3u8) streams. These tools are perfect for developers, testers, or anyone working with video streams.
Key Features:
DRM Detection: Instantly checks for the
#EXT-X-KEYtag to see if a stream is encrypted. - Variant Analysis: Parses master playlists to display available stream variants, including bandwidth, resolution, and codecs.
- Cross-Platform: Native scripts are available for both Bash (Linux/macOS) and PowerShell (Windows).
- No Dependencies: The scripts use standard, built-in command-line tools, so no external libraries are required.
- Docker Support: You can also run the script in a Docker container for a consistent environment on any system.
The scripts are interactive, allowing you to check multiple stream URLs in a single session.
