I know there are many threads/requests created about this topic
Just wanted to get some feedback on use cases and how to implement (if possible) to give the devs one topic to look at.
In my case, there have been maybe 5 cases where I wanted this functionality.
In all but one case, it would have proved useless.
Thinking the EPG Guide data was inaccurate, I wanted to override it and schedule manual recordings.
The guide data was corrected before the recordings happened and I wouldn't have got what I wanted.
There is a work-around for channels that have guide data where you pick whatever is shown closest to the start time and choose to manually record it from the guide with an end-padding of your choice.
The one case where it would have helped is for a channel that has no guide data (this would help with some TVE channels) and I could have recorded based on day/time/duration.
I would like to see Manual recordings implemented in the DVR web UI to start with.
What should be the name of the Movie/Show that's recorded, manually named, or picked from what the guide start time says is playing (if there is one)?
How will it be initiated, Advanced Pass Date/Time/Channel#?
I'm not ready to dive into this work-around yet, if anyone has, please comment.
