I am attempting to map an EPG to an M3U playlist of legal IPTV channels using the "manage lineup" function in Channels.
Since these channels come from a few different counties I am using the EPG that contains data from around the world from https://epgshare01.online
I am specifically using the EPG: epg_ripper_ALL_SOURCES1
Linked here is the PDF of what is included in this EPG source:
I am using this PDF to find the exact name of the EPG I want to match to a channel. The issue I am having is that when I search in the "Manage Lineup" function I usually get no results.
Can someone explain what part of the XML channels is looking at when I search for a channel?
I really want to avoid the complexity of external M3U editors, If I can figure this out everything I want to do can be accomplished in Channels.
Thank you
