Mlb network and all turner networks not working
not at home right now (trying to watch in my tesla) but the logs say couldn't generate stream playlist and then probe failed for live stream. can send full logs when I get home tonight.
anyone else having issues?
Must be you, as WarnerMedia and MLB are all working fine here. (Assuming TVE and not cable.)
not an xfinity specific issue. mlb network is at&t auth...
tnt stopped working last night when I was trying to watch the tournament, but tbs and tru tv were still working. today, none of the three work.
edit: mlb network is working again. the turner nets are not (which are all xfinity).
I think you need to specify which provider you are using for each parent network. Are you claiming your auth for WarnerMedia networks (TNT, TBS, etc) is coming from Xfinity/Comcast, or do you believe that Xfinity owns those networks? And why did you lump MLB into this issue, as that is a completely separate network/auth issue?
is this a real question? do you really think (having interacted with me on this forum more times than i can count) that i think xfinity owns those networks? really?
because the logs showed the same failure messages and the behavior in the web app was literally exactly the same. that's why.
Of course, you're right. I apologize, as I don't think I had my coffee yet. I wasn't particularly looking at the user, but had in my mind the many posts over the past couple weeks about downed TVE channels, and why were the channels working in their insert OTT provider here app, but not with Channels.
Separately, and back on topic, this seems to be a frequent Xfinity/Comcast problem though, with them slightly changing their auth process every few months—probably to make it more annoying for users, and to reduce password sharing.
mlb network is broken again.
log says could not find codec parameters and then probe failed for live stream.
