MPEG TS not working anymore
Every single time I run my M3u playlist on channels, I always get signal drops or tuner quit, etc. I also get stutters every once in awhile. How do I know that this is a channels issue and not my IPTV signal? I run the same signal on a different app and keep it for hours and no problems there. The server is running on an intel mac mini 8gb ram so shouldnt be having these kind of issues. Its hard to watch live TV using channelsDVR for fear of constantly getting signal interruptions.
just submitted diagnostic logs
New issue this morning... MPEG TS "streaming to the tuner failed".
Apple Tv 4K. Current Gen
Its on all the clients. Web, apple tv, shield. Randomly last night it just stopped taking in the MPEG-TS signal.
Yeah, this is a specific thing that started last night with it not accepting the MPEG TS signal. Server is hardwired and so is the client.
let me also state that as of last night, all my personal sections are no longer generating any info. All the playlists I had organized are gone even though they still remain in my channels collections. Something weird happened.
m3u playlist. works fine as an mpeg-TS signal on other apps.
When you added the custom source to the Channels DVR, did you use the Mpeg-ts under Stream Source and how many channels does the M3U have with it?
I think, have read, streams that are pure .ts often lose connection.
I have read using Threadfin or xTeVe can smooth them out but have not tried,
is that possible in CHDVR?
Yes, of course. As I said, everything was working fine and then suddenly the MPEG-TS signal doesnt get accepted by channels. I run the the same playlist on other external players and they have zero issues with the mpeg TS signal. If I convert to HLS, the quality is pretty bad but then channels does take it. Makes no sense why it stopped working all of a sudden.
"The media could not be loaded, either because the server or network failed or because the format is not supported. " from the web player.
If you search the forum for that error, you will see posts going back to 2017.
It's a generic error message with many root causes.
Try using the DVR web UI player in a non-chromium browser, like Firefox or Safari.
I'm having the exact same issues. This all started about a week ago. Also running a HDHomerun Flex Duo and it still works fine. Only M3Us not working.
I remember this same issue cropping up a couple of months ago. A server (beta) update broke m3u's. If I remember correctly, think it had something to do with the user agent on the server side, but fixing that is way above my pay grade.
