Multiple AppleTV's - syncing settings
Newbie here. I have my Channels DVR up and running, but now I'm working with the clients trying to get multiple Apple TV devices to look/feel the same. It seems that both devices are completely independent when I go in and specify favorite channels and hide others. Is there a way to make the devices "sync" so I don't have to do it on every device?
Currently, settings are device/client specific. Syncing of settings is on the to-do list.
One workaround you can use right now is to set the favorites as you want them in the DVR web UI. They are pulled the very first time the app is launched. So if you get the DVR set and then delete and re-download the app on each device it will pull the favorites from the server. Obviously this is a one time thing but if you only need to do it once it can save time.
