It seems that when combining multiple sources, I'm getting inconsistencies across platforms when accessing guide data. Here's my source setup:
- Locast
- TV Everywhere
- HD Homerun Quatro
(I have them in the above order for priority).
On the web interface and Android devices, when accessing the guide data, I can see all of the channels and tune them as I see fit (low dotted numbers as OTA tuner, 59xx range for Locast, and 6xxx for TVE).
On FireTV and iOS devices, duplicated channels appear to hidden, regardless of whether I have them marked as favorites, or whether I select to show 'all'. There are no channel number collisions, so this 'hiding' appears to be totally unnecessary.
So, for example, in my area (Boston), I should be able to see WCVB across all sources as 5.1 (HDHR), 5902 (Locast), and 6001 (TVE). That's not the case on iOS or FireTV.
I understand the desire to prioritize while processing the DVR schedule, but if I choose to manually tune a channel source, I should be able to see it in the guide and select my source as I choose).
Any advice?
(edit) -- correction to the above -- Android suffers from the same 'hiding' when reprioritizing the tuners. The web interface behaves as it should.
I would just think that, with respect to the channel guide, that All means all... It does in the Web interface :-/
