I have the default settings for streaming, albeit I have tried many iterations to see if it would play, i.e. 6mps and 4 mbs , stream, direct, and original etc all with no positive out come.
As for streaming messages and logs if you think it will help here they are:
2024/02/03 08:20:56.572866 [TVE] action=exception err=&runtime.ExceptionDetails{ExceptionID:2, Text:"Uncaught (in promise)", LineNumber:0, ColumnNumber:49792, ScriptID:"34", URL:"https://cdn.opecloud.com/ope-fox.js", StackTrace:(*runtime.StackTrace)(0xc00322ea40), Exception:(*runtime.RemoteObject)(0xc002a65ef0), ExecutionContextID:2, ExceptionMetaData:easyjson.RawMessage(nil)} exp=&runtime.RemoteObject{Type:"object", Subtype:"error", ClassName:"Error", Value:easyjson.RawMessage(nil), UnserializableValue:"", Description:"Error: [object Object]\n at https://cdn.opecloud.com/ope-fox.js:1:49793", DeepSerializedValue:(*runtime.DeepSerializedValue)(nil), ObjectID:"2659086891717329001.2.4", Preview:(*runtime.ObjectPreview)(0xc001b2c540), CustomPreview:(*runtime.CustomPreview)(nil)} preview=&runtime.ObjectPreview{Type:"object", Subtype:"error", Description:"Error: [object Object]\n at https://cdn.opecloud.com/ope-fox.js:1:49793", Overflow:false, Properties:[]*runtime.PropertyPreview{(*runtime.PropertyPreview)(0xc001ee3400), (*runtime.PropertyPreview)(0xc001ee3450)}, Entries:[]*runtime.EntryPreview(nil)} value=Error: [object Object]
2024/02/03 08:20:57.399526 [TVE] action=exception err=&runtime.ExceptionDetails{ExceptionID:3, Text:"Uncaught", LineNumber:0, ColumnNumber:417558, ScriptID:"115", URL:"https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js", StackTrace:(*runtime.StackTrace)(0xc0034acbc0), Exception:(*runtime.RemoteObject)(0xc002e6db00), ExecutionContextID:2, ExceptionMetaData:easyjson.RawMessage(nil)} exp=&runtime.RemoteObject{Type:"object", Subtype:"error", ClassName:"ReferenceError", Value:easyjson.RawMessage(nil), UnserializableValue:"", Description:"ReferenceError: OvaMediaPlayer is not defined at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:417559) at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:423453) at i (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:87555) at po. (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:89144) at p (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:3031) at m (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2705) at l (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:628) at a.trigger (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2598) at Z.s.set (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:101311) at io._onOvaMediaPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:409485)", DeepSerializedValue:(*runtime.DeepSerializedValue)(nil), ObjectID:"2659086891717329001.2.5", Preview:(*runtime.ObjectPreview)(0xc0010a85b0), CustomPreview:(*runtime.CustomPreview)(nil)} preview=&runtime.ObjectPreview{Type:"object", Subtype:"error", Description:"ReferenceError: OvaMediaPlayer is not defined at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:417559) at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:423453) at i (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:87555) at po. (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:89144) at p (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:3031) at m (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2705) at l (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:628) at a.trigger (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2598) at Z.s.set (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:101311) at io._onOvaMediaPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:409485)", Overflow:true, Properties:[]*runtime.PropertyPreview{(*runtime.PropertyPreview)(0xc003a391d0), (*runtime.PropertyPreview)(0xc003a39220), (*runtime.PropertyPreview)(0xc003a39270), (*runtime.PropertyPreview)(0xc003a392c0), (*runtime.PropertyPreview)(0xc003a39310)}, Entries:[]*runtime.EntryPreview(nil)} value=ReferenceError: OvaMediaPlayer is not defined at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:417559) at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:423453) at i (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:87555) at po. (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:89144) at p (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:3031) at m (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2705) at l (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:628) at a.trigger (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2598) at Z.s.set (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:101311) at io._onOvaMediaPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:409485)
2024/02/03 08:20:57.460891 [TVE] action=exception err=&runtime.ExceptionDetails{ExceptionID:4, Text:"Uncaught", LineNumber:0, ColumnNumber:417558, ScriptID:"115", URL:"https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js", StackTrace:(*runtime.StackTrace)(0xc003544400), Exception:(*runtime.RemoteObject)(0xc002baf9e0), ExecutionContextID:2, ExceptionMetaData:easyjson.RawMessage(nil)} exp=&runtime.RemoteObject{Type:"object", Subtype:"error", ClassName:"ReferenceError", Value:easyjson.RawMessage(nil), UnserializableValue:"", Description:"ReferenceError: OvaMediaPlayer is not defined at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:417559) at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:423453) at i (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:87555) at po. (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:89144) at p (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:3031) at m (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2705) at l (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:628) at a.trigger (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2598) at Z.s.set (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:101311) at io._onOvaMediaPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:409485)", DeepSerializedValue:(*runtime.DeepSerializedValue)(nil), ObjectID:"2659086891717329001.2.6", Preview:(*runtime.ObjectPreview)(0xc000f24310), CustomPreview:(*runtime.CustomPreview)(nil)} preview=&runtime.ObjectPreview{Type:"object", Subtype:"error", Description:"ReferenceError: OvaMediaPlayer is not defined at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:417559) at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:423453) at i (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:87555) at po. (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:89144) at p (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:3031) at m (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2705) at l (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:628) at a.trigger (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2598) at Z.s.set (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:101311) at io._onOvaMediaPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:409485)", Overflow:true, Properties:[]*runtime.PropertyPreview{(*runtime.PropertyPreview)(0xc0006e2eb0), (*runtime.PropertyPreview)(0xc0006e2f00), (*runtime.PropertyPreview)(0xc0006e2f50), (*runtime.PropertyPreview)(0xc0006e2fa0), (*runtime.PropertyPreview)(0xc0006e2ff0)}, Entries:[]*runtime.EntryPreview(nil)} value=ReferenceError: OvaMediaPlayer is not defined at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:417559) at po._onPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:423453) at i (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:87555) at po. (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:89144) at p (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:3031) at m (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2705) at l (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:628) at a.trigger (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:2598) at Z.s.set (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:101311) at io._onOvaMediaPlayerLoaded (https://vidstat.taboola.com/vpaid/units/33_7_4/infra/cmTagFEED_MANAGER.js:1:409485)
2024/02/03 08:20:59.392395 [TVE] action=error_response type=Document error=net::ERR_ABORTED url=https://sync.1rx.io/usersync2/aniview ip=69.194.240.13
2024/02/03 08:21:07.624435 [TVE] action=error_response type=Image error=net::ERR_TOO_MANY_REDIRECTS url=https://ads.stickyadstv.com/user-registering ip=38.98.139.151
2024/02/03 08:21:07.786711 [TVE] action=exception err=&runtime.ExceptionDetails{ExceptionID:5, Text:"Uncaught (in promise)", LineNumber:0, ColumnNumber:49792, ScriptID:"34", URL:"https://cdn.opecloud.com/ope-fox.js", StackTrace:(*runtime.StackTrace)(0xc002188d40), Exception:(*runtime.RemoteObject)(0xc00313a480), ExecutionContextID:2, ExceptionMetaData:easyjson.RawMessage(nil)} exp=&runtime.RemoteObject{Type:"object", Subtype:"error", ClassName:"Error", Value:easyjson.RawMessage(nil), UnserializableValue:"", Description:"Error: [object Object]\n at https://cdn.opecloud.com/ope-fox.js:1:49793", DeepSerializedValue:(*runtime.DeepSerializedValue)(nil), ObjectID:"2659086891717329001.2.7", Preview:(*runtime.ObjectPreview)(0xc0003aa000), CustomPreview:(*runtime.CustomPreview)(nil)} preview=&runtime.ObjectPreview{Type:"object", Subtype:"error", Description:"Error: [object Object]\n at https://cdn.opecloud.com/ope-fox.js:1:49793", Overflow:false, Properties:[]*runtime.PropertyPreview{(*runtime.PropertyPreview)(0xc001336140), (*runtime.PropertyPreview)(0xc001336190)}, Entries:[]*runtime.EntryPreview(nil)} value=Error: [object Object]
2024/02/03 08:21:14.862475 [TVE] action=page_ready
2024/02/03 08:21:14.862988 [TVE] action=wait_for_page done=true reason=page_ready
2024/02/03 08:21:14.873441 [TVE] action=click_interstitial
2024/02/03 08:21:15.155179 [TVE] action=tvejs msg="foxSportsSelect: path=/live"
2024/02/03 08:21:15.190972 [TVE] action=wait_for_interstitial timeout=12s
2024/02/03 08:21:15.193154 [TVE] action=request type=Document method=GET url=https://www.foxsports.com/provider/register
2024/02/03 08:21:15.193154 [TVE] action=foxsportsauth step=register
2024/02/03 08:21:15.705467 [TVE] action=error_response type=Image error=net::ERR_ABORTED url=https://ag.innovid.com/1x1.gif ip=3.19.183.195
2024/02/03 08:21:15.706744 [TVE] action=error_response type=Image error=net::ERR_ABORTED url=https://dt.adsafeprotected.com/dt ip=44.229.247.206
