Native resolution and scaled resolution question
When playing most tv shows, and displaying the stats, I am seeing that both native and scaled are at 1920x1080. And when playing 720p video from TVE the Native shows 1280x720 with scaled at 1920x1080. However when playing a 4k movie, the
stats show Native at 3840x2160 with Scaled at 1920x1080
Is there down scaling going on? Or why are the stats showing that?
Thanks
If this is on an android player past comments suggest that the info there is not correct and it is not being scaled down. If this is happening on Apple devices then that’s different because I think they report correct scaling info.
Found it here
Thanks. I thought that I had seen that the stats display was not accurate if running it on Nvidia Shield Tv which is what I am doing. Could not locate it when I searched earlier. I really appreciate the explanation and response.
