Need phantom guide entry
I'm trying to convert from Fubo to DirectTV Stream. There are 4 channels (SciFi, FreeForm, Halmark, and Nat Geo), which I get with my subscription to DTV, but do not come through to Channels using TVE.
I will need to sign in directly to DTV to watch or record these, but what I'm looking for is to get them included in the Channels Guide so I can see what's on that I might want to see. Can this be done?
Take a look at the Channels Plug-ins. You can record from DTV and have the guide data as well. If you are good at following instructions you should be able to make them work.
I searched for this and found nothing. Do you have a link?
https://share.google/aimode/dTXqHD8I9kZviyllC
I followed along as best as I could. I got PrismCast up and running under Docker (Windows 10), but when I try to add DirectTV, it says I need to complete the login in the Chrome window, but I have no Chrome window. It just hangs there waiting.
I tried setting the Chrome path, but I'm not sure I did it right.
Ask here:
I think I found the problem in getting PrisimCast working. DTV was logging me in based on saved information on my computer, so it did not go through a login sequence and did not authenticate. I managed to kill the auto login and got things working.
