I have a Dune-HD Pro 4K Plus II and a HD HomeRun Quatro.
When I'm not using the Channels App I receive a notification saying that the Network tuner is disconnected, but when I'm using the Channels App it works ok.
Has anyone else experienced this?
This message comes from the built-in Live Channels app. You can delete or disable it and the notification will stop.
Whereabouts in the settings can I disable it?
In the Android settings under Apps
Thank you
