Something is up with NFL Network again. This morning, it failed to record:
Even odder, I'm not sure why it thinks it tried again after the failure and created a zero-byte file:
I can stream with no problem at https://www.nfl.com/network/watch/nfl-network-live. I also rescanned NFL Network and it worked successfully. However, when I go to play, it still errors out:
2023/10/13 10:07:05.823142 [TNR] Opened connection to TVE-Cox for ch6192 NFL
2023/10/13 10:07:05.833141 [HLS] Starting live stream for channel 6192 from 2002:60fd:1d03:1:4925:ee91:88bd:7d9d (bitrate=5000)
2023/10/13 10:07:06.127634 [HTTP] | 200 | 2.3564948s | 2002:60fd:1d03:1:4925:ee91:88bd:7d9d | GET "/dvr/files?all=true&raw=false"
2023/10/13 10:07:06.465855 [HTTP] | 200 | 79.4929ms | 2002:60fd:1d03:1:4925:ee91:88bd:7d9d | GET "/dvr/recordings/upnext"
2023/10/13 10:07:06.562120 [HLS] ffmpeg: ch6192-dANY-ip2002-60fd-1d03-1-4925-ee91-88bd-7d9d-remux: Output file #0 does not contain any stream
2023/10/13 10:07:06.572115 [HTTP] | 200 | 648.7504ms | 127.0.0.1 | POST "/hls/progress?key=ch6192-dANY-ip2002-60fd-1d03-1-4925-ee91-88bd-7d9d-remux"
2023/10/13 10:07:06.632113 [HTTP] | 200 | 1.0274891s | 2002:60fd:1d03:1:4925:ee91:88bd:7d9d | GET "/devices/ANY/channels/6192/hls/master.m3u8?abr=false"
2023/10/13 10:07:06.739025 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip2002-60fd-1d03-1-4925-ee91-88bd-7d9d: Stream stopped
2023/10/13 10:07:06.739025 [HLS] Stopping transcoder session ch6192-dANY-ip2002-60fd-1d03-1-4925-ee91-88bd-7d9d
2023/10/13 10:07:06.739535 [TNR] Closed connection to TVE-Cox for ch6192 NFL
2023/10/13 10:07:06.744036 [ERR] Probe failed for live stream after 909.8934ms and 0 bytes
Submitted diagnostics: b01b2a6c-3271-4e93-807b-1e7cbb09fe51
