On the latest pre-release and get this error.
Are you able to get it to work on the NFL Network's website:
I seem to be having issue there, too (Cox) in every browser (Firefox, Chrome, Edge)--even with the Pi Hole off--so have reason to believe the problem is on the NFL's end. Since Channels just uses the NFL Network's website stream, if that is down, so is Channels.
Works fine in all my browsers and in the NFL app. Just doesnt work in Channels.
I just updated to today's release 5.12 and still no joy. I'm suprised Im the only one.
I changed my story. I can get it to work in the browser (Firefox), but had to completely turn off autoplay blocking. Chrome and Edge still refuse to play, but it is working in the NFL app.
I am able to re-authenticate the station no problem, although it seems to take a long time. But yes, just like you it will not play in Channels. Something seems to have changed on the NFL's end that is causing hiccups.
Submitted diagnostics 1f9ab825-d5c4-495a-b3b9-ffb6c2db1d55.
Okay, I can definitely get NFL Network to play in Chrome (101.0.4951.67) on the server. When I rescan the station, I see this in the tve_chrome.log:
DevTools listening on ws://127.0.0.1:55704/devtools/browser/fa6add5a-bc63-4ccc-8fb0-76dcc908d446
[0513/082445.539:INFO:CONSOLE(11)] "A preload for 'https://www.nfl.com/compiledassets/css/base.css?_t=450963c95b349de85517a5b17227f17e' is found, but is not used because the request credentials mode does not match. Consider taking a look at crossorigin attribute.", source: https://www.nfl.com/network/watch/nfl-network-live (11)
[0513/082445.540:INFO:CONSOLE(11)] "A preload for 'https://www.nfl.com/compiledassets/css/dark-base.css?_t=44d34ac976922a32302574cbf71a828e' is found, but is not used because the request credentials mode does not match. Consider taking a look at crossorigin attribute.", source: https://www.nfl.com/network/watch/nfl-network-live (11)
[0513/082445.563:INFO:CONSOLE(11)] "A preload for 'https://www.nfl.com/compiledassets/theming/936e9c4e6b4be40493ce5b361703787b' is found, but is not used because the request credentials mode does not match. Consider taking a look at crossorigin attribute.", source: https://www.nfl.com/network/watch/nfl-network-live (11)
[0513/082450.431:INFO:CONSOLE(3)] "fired plugins", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (3)
[0513/082453.414:INFO:CONSOLE(15)] "🚀 container.buildInfo.environment is deprecated.Please use `container.environment.stage` instead", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (15)
[0513/082453.415:INFO:CONSOLE(15)] "🚀 container.buildInfo.environment is deprecated.Please use `container.environment.stage` instead", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (15)
[0513/082507.713:INFO:CONSOLE(154)] "tvejs nflSelect: path=/network/watch/nfl-network-live", source: tveinterhelper.js (154)
[0513/082509.240:INFO:CONSOLE(73)] "%c %c[error] SSO Communication Timeout [object Object]", source: https://cdns.us1.gigya.com/js/gigya.js?apikey=3_Qa8TkWpIB8ESCBT8tY2TukbVKgO5F6BJVc7N1oComdwFzI7H2L9NOWdm11i_BY9f (73)
[0513/082509.622:INFO:CONSOLE(3)] "fired plugins", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (3)
[0513/082511.605:INFO:CONSOLE(11)] "A preload for 'https://www.nfl.com/compiledassets/css/base.css?_t=450963c95b349de85517a5b17227f17e' is found, but is not used because the request credentials mode does not match. Consider taking a look at crossorigin attribute.", source: https://www.nfl.com/activate/29GK5M (11)
[0513/082511.607:INFO:CONSOLE(11)] "A preload for 'https://www.nfl.com/compiledassets/theming/936e9c4e6b4be40493ce5b361703787b' is found, but is not used because the request credentials mode does not match. Consider taking a look at crossorigin attribute.", source: https://www.nfl.com/activate/29GK5M (11)
[0513/082517.670:INFO:CONSOLE(11)] "USP is not accessible", source: https://www.nfl.com/activate/29GK5M (11)
[0513/082518.363:INFO:CONSOLE(3)] "fired plugins", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (3)
[0513/082521.266:INFO:CONSOLE(15)] "🚀 container.buildInfo.environment is deprecated.Please use `container.environment.stage` instead", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (15)
[0513/082521.269:INFO:CONSOLE(15)] "🚀 container.buildInfo.environment is deprecated.Please use `container.environment.stage` instead", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (15)
[0513/082521.270:INFO:CONSOLE(15)] "🚀 container.buildInfo.environment is deprecated.Please use `container.environment.stage` instead", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (15)
[0513/082532.012:INFO:CONSOLE(154)] "tvejs nflSelect: path=/activate/29GK5M", source: tveinterhelper.js (154)
[0513/082532.460:INFO:CONSOLE(0)] "The resource https://www.nfl.com/compiledassets/css/base.css?_t=450963c95b349de85517a5b17227f17e was preloaded using link preload but not used within a few seconds from the window's load event. Please make sure it has an appropriate `as` value and it is preloaded intentionally.", source: https://www.nfl.com/activate/29GK5M (0)
[0513/082532.461:INFO:CONSOLE(0)] "The resource https://www.nfl.com/compiledassets/theming/936e9c4e6b4be40493ce5b361703787b was preloaded using link preload but not used within a few seconds from the window's load event. Please make sure it has an appropriate `as` value and it is preloaded intentionally.", source: https://www.nfl.com/activate/29GK5M (0)
[0513/082534.846:INFO:CONSOLE(3)] "fired plugins", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (3)
[0513/082541.563:INFO:CONSOLE(0)] "[.WebGL-0000776E00678E00]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPixels", source: https://www.cox.com/_Incapsula_Resource?CWUDNSAI=42&xinfo=5-28631380-0%20PNNN%20RT%281652444739471%2048%29%20q%280%20-1%20-1%200%29%20r%280%20-1%29%20B10%2814%2c0%2c0%29%20U5&incident_id=701000830115075570-165965237239747781&edet=10&cinfo=0e0000009625&rpinfo=0&mth=GET (0)
[0513/082546.983:INFO:CONSOLE(406)] "onSuccessUrl https://login.cox.com/app/ccires_tveverywhere_1/exk1jha9awwp564kZ0h8/sso/saml?SAMLRequest=hVPLbtswELz3KwTe9XTc2oSlwI1r1ICbqLbSQy4BJa8iOhKpcik%2F%2Fr6U%2FKjbpO6Rg53Z2Z3l6HZXldYGFHIpQuI7HrFAZHLFxUtIHpOpPSC30YcRsqoMajpudCEW8LMB1NYYEZQ2vDspsKlALUFteAaPi3lICq1rpK6LtcMMyWErmYKTycogbqvmLsff5m8kiDUx0lww3fk5qZTyhQvD3nUKrK7dLOMK8FlvwJjfbwtQ8Oy7sHv11wUbsu227n%2B8eX3yioGLKLuOxJpKlUE3Q0hyViIQazYJCfO5N1znkPaKQc75MMg%2BDYM0W%2FdTvze8SU0RxgyRb%2BA3DbGBmUDNhA5J4AWB7fVtv5f4AQ36tDdwAn%2FwRKxYSS0zWX7m4rDSRgkqGXKkglWAVGe0XQQNHI%2BmhyKkX5MktuOHZUKsH6dogjYaE5ZAegjjulZ9bEyiQ3a0c6wuFa4LsFM0JDpnaVjOm0BH7mWD6HQqX3YaRGsdo5EuVK33dAFYS7FK5NHFAf63jdMMFHbaFHO1smum9P7%2Fjv5uGB1N%2FmnrCN2bprNJLEue7a1xWcrtnQKmTdhaNdBdTcX09W21CF%2FZeVdKtWKmBwhNrGXcyn9vWMlzDuriY7xr3ZXCTqFgZW7L3L2fzol79rnMZG3O4%2Fw%2B%2FkNQs0lkKs8jXuJn8Ex23%2FnK0S8%3D&RelayState=d69bc63d-e7aa-4ecb-a99f-3a26530473ae&SigAlg=http%3A%2F%2Fwww.w3.org%2F2000%2F09%2Fxmldsig%23rsa-sha1&Signature=J2sgLPgAKo%2FSYXgCNiC8tDzFCGWGA8Zt2I8MEfOdlc%2B8HhWLNstegvA1kRrgSqax%2B%2BqyemCv%2BjosGh4MjjPJ9Gg83XsgQ6iPFeSQVkc9xilMfR%2Bxl%2FRGc7VCViFXUD2cGqzs%2B95hF38F0h9MpMyxCs20SAdPnkSr3Uk8z8EisW7LZdumF6mDTJah2aOKd4kJPlepq7oOTBO7Jq2PbgCCDX9v7sL3tOipUuyqZ%2FgALHvtuzqQjaBJSymQSBpQD007kY9V6CYn0RXdYhh4OHJkPaxRaZAYIY%2F6xwO9pCK4QZwLdehPQJNmYdyRfApQQ%2FLxhRY%2F3LX8tbPMNfyRoqJzxw%3D%3D", source: https://www.cox.com/content/dam/cox/okta/loginwidget.html?fromURI=https%3A%2F%2Flogin.cox.com%2Fapp%2Fccires_tveverywhere_1%2Fexk1jha9awwp564kZ0h8%2Fsso%2Fsaml%3FSAMLRequest%3DhVPLbtswELz3KwTe9XTc2oSlwI1r1ICbqLbSQy4BJa8iOhKpcik%252F%252Fr6U%252FKjbpO6Rg53Z2Z3l6HZXldYGFHIpQuI7HrFAZHLFxUtIHpOpPSC30YcRsqoMajpudCEW8LMB1NYYEZQ2vDspsKlALUFteAaPi3lICq1rpK6LtcMMyWErmYKTycogbqvmLsff5m8kiDUx0lww3fk5qZTyhQvD3nUKrK7dLOMK8FlvwJjfbwtQ8Oy7sHv11wUbsu227n%252B8eX3yioGLKLuOxJpKlUE3Q0hyViIQazYJCfO5N1znkPaKQc75MMg%252BDYM0W%252FdTvze8SU0RxgyRb%252BA3DbGBmUDNhA5J4AWB7fVtv5f4AQ36tDdwAn%252FwRKxYSS0zWX7m4rDSRgkqGXKkglWAVGe0XQQNHI%252BmhyKkX5MktuOHZUKsH6dogjYaE5ZAegjjulZ9bEyiQ3a0c6wuFa4LsFM0JDpnaVjOm0BH7mWD6HQqX3YaRGsdo5EuVK33dAFYS7FK5NHFAf63jdMMFHbaFHO1smum9P7%252Fjv5uGB1N%252FmnrCN2bprNJLEue7a1xWcrtnQKmTdhaNdBdTcX09W21CF%252FZeVdKtWKmBwhNrGXcyn9vWMlzDuriY7xr3ZXCTqFgZW7L3L2fzol79rnMZG3O4%252Fw%252B%252FkNQs0lkKs8jXuJn8Ex23%252FnK0S8%253D%26RelayState%3Dd69bc63d-e7aa-4ecb-a99f-3a26530473ae%26SigAlg%3Dhttp%253A%252F%252Fwww.w3.org%252F2000%252F09%252Fxmldsig%2523rsa-sha1%26Signature%3DJ2sgLPgAKo%252FSYXgCNiC8tDzFCGWGA8Zt2I8MEfOdlc%252B8HhWLNstegvA1kRrgSqax%252B%252BqyemCv%252BjosGh4MjjPJ9Gg83XsgQ6iPFeSQVkc9xilMfR%252Bxl%252FRGc7VCViFXUD2cGqzs%252B95hF38F0h9MpMyxCs20SAdPnkSr3Uk8z8EisW7LZdumF6mDTJah2aOKd4kJPlepq7oOTBO7Jq2PbgCCDX9v7sL3tOipUuyqZ%252FgALHvtuzqQjaBJSymQSBpQD007kY9V6CYn0RXdYhh4OHJkPaxRaZAYIY%252F6xwO9pCK4QZwLdehPQJNmYdyRfApQQ%252FLxhRY%252F3LX8tbPMNfyRoqJzxw%253D%253D&partner=nfl (406)
[0513/082554.224:INFO:CONSOLE(417)] "Uncaught TypeError: coxLogin.updateRememberMeCookie is not a function", source: https://www.cox.com/content/dam/cox/okta/loginwidget.html?fromURI=https%3A%2F%2Flogin.cox.com%2Fapp%2Fccires_tveverywhere_1%2Fexk1jha9awwp564kZ0h8%2Fsso%2Fsaml%3FSAMLRequest%3DhVPLbtswELz3KwTe9XTc2oSlwI1r1ICbqLbSQy4BJa8iOhKpcik%252F%252Fr6U%252FKjbpO6Rg53Z2Z3l6HZXldYGFHIpQuI7HrFAZHLFxUtIHpOpPSC30YcRsqoMajpudCEW8LMB1NYYEZQ2vDspsKlALUFteAaPi3lICq1rpK6LtcMMyWErmYKTycogbqvmLsff5m8kiDUx0lww3fk5qZTyhQvD3nUKrK7dLOMK8FlvwJjfbwtQ8Oy7sHv11wUbsu227n%252B8eX3yioGLKLuOxJpKlUE3Q0hyViIQazYJCfO5N1znkPaKQc75MMg%252BDYM0W%252FdTvze8SU0RxgyRb%252BA3DbGBmUDNhA5J4AWB7fVtv5f4AQ36tDdwAn%252FwRKxYSS0zWX7m4rDSRgkqGXKkglWAVGe0XQQNHI%252BmhyKkX5MktuOHZUKsH6dogjYaE5ZAegjjulZ9bEyiQ3a0c6wuFa4LsFM0JDpnaVjOm0BH7mWD6HQqX3YaRGsdo5EuVK33dAFYS7FK5NHFAf63jdMMFHbaFHO1smum9P7%252Fjv5uGB1N%252FmnrCN2bprNJLEue7a1xWcrtnQKmTdhaNdBdTcX09W21CF%252FZeVdKtWKmBwhNrGXcyn9vWMlzDuriY7xr3ZXCTqFgZW7L3L2fzol79rnMZG3O4%252Fw%252B%252FkNQs0lkKs8jXuJn8Ex23%252FnK0S8%253D%26RelayState%3Dd69bc63d-e7aa-4ecb-a99f-3a26530473ae%26SigAlg%3Dhttp%253A%252F%252Fwww.w3.org%252F2000%252F09%252Fxmldsig%2523rsa-sha1%26Signature%3DJ2sgLPgAKo%252FSYXgCNiC8tDzFCGWGA8Zt2I8MEfOdlc%252B8HhWLNstegvA1kRrgSqax%252B%252BqyemCv%252BjosGh4MjjPJ9Gg83XsgQ6iPFeSQVkc9xilMfR%252Bxl%252FRGc7VCViFXUD2cGqzs%252B95hF38F0h9MpMyxCs20SAdPnkSr3Uk8z8EisW7LZdumF6mDTJah2aOKd4kJPlepq7oOTBO7Jq2PbgCCDX9v7sL3tOipUuyqZ%252FgALHvtuzqQjaBJSymQSBpQD007kY9V6CYn0RXdYhh4OHJkPaxRaZAYIY%252F6xwO9pCK4QZwLdehPQJNmYdyRfApQQ%252FLxhRY%252F3LX8tbPMNfyRoqJzxw%253D%253D&partner=nfl (417)
[0513/082555.342:INFO:CONSOLE(541)] "[object Object]", source: https://www.cox.com/content/dam/cox/okta/loginwidget.html?fromURI=https%3A%2F%2Flogin.cox.com%2Fapp%2Fccires_tveverywhere_1%2Fexk1jha9awwp564kZ0h8%2Fsso%2Fsaml%3FSAMLRequest%3DhVPLbtswELz3KwTe9XTc2oSlwI1r1ICbqLbSQy4BJa8iOhKpcik%252F%252Fr6U%252FKjbpO6Rg53Z2Z3l6HZXldYGFHIpQuI7HrFAZHLFxUtIHpOpPSC30YcRsqoMajpudCEW8LMB1NYYEZQ2vDspsKlALUFteAaPi3lICq1rpK6LtcMMyWErmYKTycogbqvmLsff5m8kiDUx0lww3fk5qZTyhQvD3nUKrK7dLOMK8FlvwJjfbwtQ8Oy7sHv11wUbsu227n%252B8eX3yioGLKLuOxJpKlUE3Q0hyViIQazYJCfO5N1znkPaKQc75MMg%252BDYM0W%252FdTvze8SU0RxgyRb%252BA3DbGBmUDNhA5J4AWB7fVtv5f4AQ36tDdwAn%252FwRKxYSS0zWX7m4rDSRgkqGXKkglWAVGe0XQQNHI%252BmhyKkX5MktuOHZUKsH6dogjYaE5ZAegjjulZ9bEyiQ3a0c6wuFa4LsFM0JDpnaVjOm0BH7mWD6HQqX3YaRGsdo5EuVK33dAFYS7FK5NHFAf63jdMMFHbaFHO1smum9P7%252Fjv5uGB1N%252FmnrCN2bprNJLEue7a1xWcrtnQKmTdhaNdBdTcX09W21CF%252FZeVdKtWKmBwhNrGXcyn9vWMlzDuriY7xr3ZXCTqFgZW7L3L2fzol79rnMZG3O4%252Fw%252B%252FkNQs0lkKs8jXuJn8Ex23%252FnK0S8%253D%26RelayState%3Dd69bc63d-e7aa-4ecb-a99f-3a26530473ae%26SigAlg%3Dhttp%253A%252F%252Fwww.w3.org%252F2000%252F09%252Fxmldsig%2523rsa-sha1%26Signature%3DJ2sgLPgAKo%252FSYXgCNiC8tDzFCGWGA8Zt2I8MEfOdlc%252B8HhWLNstegvA1kRrgSqax%252B%252BqyemCv%252BjosGh4MjjPJ9Gg83XsgQ6iPFeSQVkc9xilMfR%252Bxl%252FRGc7VCViFXUD2cGqzs%252B95hF38F0h9MpMyxCs20SAdPnkSr3Uk8z8EisW7LZdumF6mDTJah2aOKd4kJPlepq7oOTBO7Jq2PbgCCDX9v7sL3tOipUuyqZ%252FgALHvtuzqQjaBJSymQSBpQD007kY9V6CYn0RXdYhh4OHJkPaxRaZAYIY%252F6xwO9pCK4QZwLdehPQJNmYdyRfApQQ%252FLxhRY%252F3LX8tbPMNfyRoqJzxw%253D%253D&partner=nfl (541)
[0513/082555.344:INFO:CONSOLE(543)] "User %s successfully authenticated %o {REDACTED} [object Object]", source: https://www.cox.com/content/dam/cox/okta/loginwidget.html?fromURI=https%3A%2F%2Flogin.cox.com%2Fapp%2Fccires_tveverywhere_1%2Fexk1jha9awwp564kZ0h8%2Fsso%2Fsaml%3FSAMLRequest%3DhVPLbtswELz3KwTe9XTc2oSlwI1r1ICbqLbSQy4BJa8iOhKpcik%252F%252Fr6U%252FKjbpO6Rg53Z2Z3l6HZXldYGFHIpQuI7HrFAZHLFxUtIHpOpPSC30YcRsqoMajpudCEW8LMB1NYYEZQ2vDspsKlALUFteAaPi3lICq1rpK6LtcMMyWErmYKTycogbqvmLsff5m8kiDUx0lww3fk5qZTyhQvD3nUKrK7dLOMK8FlvwJjfbwtQ8Oy7sHv11wUbsu227n%252B8eX3yioGLKLuOxJpKlUE3Q0hyViIQazYJCfO5N1znkPaKQc75MMg%252BDYM0W%252FdTvze8SU0RxgyRb%252BA3DbGBmUDNhA5J4AWB7fVtv5f4AQ36tDdwAn%252FwRKxYSS0zWX7m4rDSRgkqGXKkglWAVGe0XQQNHI%252BmhyKkX5MktuOHZUKsH6dogjYaE5ZAegjjulZ9bEyiQ3a0c6wuFa4LsFM0JDpnaVjOm0BH7mWD6HQqX3YaRGsdo5EuVK33dAFYS7FK5NHFAf63jdMMFHbaFHO1smum9P7%252Fjv5uGB1N%252FmnrCN2bprNJLEue7a1xWcrtnQKmTdhaNdBdTcX09W21CF%252FZeVdKtWKmBwhNrGXcyn9vWMlzDuriY7xr3ZXCTqFgZW7L3L2fzol79rnMZG3O4%252Fw%252B%252FkNQs0lkKs8jXuJn8Ex23%252FnK0S8%253D%26RelayState%3Dd69bc63d-e7aa-4ecb-a99f-3a26530473ae%26SigAlg%3Dhttp%253A%252F%252Fwww.w3.org%252F2000%252F09%252Fxmldsig%2523rsa-sha1%26Signature%3DJ2sgLPgAKo%252FSYXgCNiC8tDzFCGWGA8Zt2I8MEfOdlc%252B8HhWLNstegvA1kRrgSqax%252B%252BqyemCv%252BjosGh4MjjPJ9Gg83XsgQ6iPFeSQVkc9xilMfR%252Bxl%252FRGc7VCViFXUD2cGqzs%252B95hF38F0h9MpMyxCs20SAdPnkSr3Uk8z8EisW7LZdumF6mDTJah2aOKd4kJPlepq7oOTBO7Jq2PbgCCDX9v7sL3tOipUuyqZ%252FgALHvtuzqQjaBJSymQSBpQD007kY9V6CYn0RXdYhh4OHJkPaxRaZAYIY%252F6xwO9pCK4QZwLdehPQJNmYdyRfApQQ%252FLxhRY%252F3LX8tbPMNfyRoqJzxw%253D%253D&partner=nfl (543)
[0513/082558.457:INFO:CONSOLE(0)] "[.WebGL-0000776E00742200]GL Driver Message (OpenGL, Performance, GL_CLOSE_PATH_NV, High): GPU stall due to ReadPixels", source: https://login.cox.com/app/ccires_tveverywhere_1/exk1jha9awwp564kZ0h8/sso/saml?SAMLRequest=hVPLbtswELz3KwTe9XTc2oSlwI1r1ICbqLbSQy4BJa8iOhKpcik%2F%2Fr6U%2FKjbpO6Rg53Z2Z3l6HZXldYGFHIpQuI7HrFAZHLFxUtIHpOpPSC30YcRsqoMajpudCEW8LMB1NYYEZQ2vDspsKlALUFteAaPi3lICq1rpK6LtcMMyWErmYKTycogbqvmLsff5m8kiDUx0lww3fk5qZTyhQvD3nUKrK7dLOMK8FlvwJjfbwtQ8Oy7sHv11wUbsu227n%2B8eX3yioGLKLuOxJpKlUE3Q0hyViIQazYJCfO5N1znkPaKQc75MMg%2BDYM0W%2FdTvze8SU0RxgyRb%2BA3DbGBmUDNhA5J4AWB7fVtv5f4AQ36tDdwAn%2FwRKxYSS0zWX7m4rDSRgkqGXKkglWAVGe0XQQNHI%2BmhyKkX5MktuOHZUKsH6dogjYaE5ZAegjjulZ9bEyiQ3a0c6wuFa4LsFM0JDpnaVjOm0BH7mWD6HQqX3YaRGsdo5EuVK33dAFYS7FK5NHFAf63jdMMFHbaFHO1smum9P7%2Fjv5uGB1N%2FmnrCN2bprNJLEue7a1xWcrtnQKmTdhaNdBdTcX09W21CF%2FZeVdKtWKmBwhNrGXcyn9vWMlzDuriY7xr3ZXCTqFgZW7L3L2fzol79rnMZG3O4%2Fw%2B%2FkNQs0lkKs8jXuJn8Ex23%2FnK0S8%3D&RelayState=d69bc63d-e7aa-4ecb-a99f-3a26530473ae&SigAlg=http%3A%2F%2Fwww.w3.org%2F2000%2F09%2Fxmldsig%23rsa-sha1&Signature=J2sgLPgAKo%2FSYXgCNiC8tDzFCGWGA8Zt2I8MEfOdlc%2B8HhWLNstegvA1kRrgSqax%2B%2BqyemCv%2BjosGh4MjjPJ9Gg83XsgQ6iPFeSQVkc9xilMfR%2Bxl%2FRGc7VCViFXUD2cGqzs%2B95hF38F0h9MpMyxCs20SAdPnkSr3Uk8z8EisW7LZdumF6mDTJah2aOKd4kJPlepq7oOTBO7Jq2PbgCCDX9v7sL3tOipUuyqZ%2FgALHvtuzqQjaBJSymQSBpQD007kY9V6CYn0RXdYhh4OHJkPaxRaZAYIY%2F6xwO9pCK4QZwLdehPQJNmYdyRfApQQ%2FLxhRY%2F3LX8tbPMNfyRoqJzxw%3D%3D&fromLoginToken=JYqV_poJfRtobWXyeAzomy182IZxEIzyl6U4Qq3m5zaulE8m4-ZD6EYfBryBxtOhu-3E6bMl8nzwQd5zEABxyeWHe_bRT6s9z_GdXKAfI5DfMc6GfHR6O_rWNHVLkJpfupSVCD2T_Jcsf_ZwtLh5zD8Ddjqk_DYeT8c82J-RphQdHHXsBIz4BHOwFsbGMH4Hh6yyLbBC_8EL4ZVxuylK2DO6VwT6zrRJ0K_zhlvXQE4tTOENiikjMGW0bAv0ruL_Uuu6e889BFEyAS2B3wxkEJCwthhJJONIwN2dAHlwfIkb5W1bro2dtK0DBMytJTxAVhXgjjiMnrTDpYk_KLqztg (0)
[0513/082558.788:INFO:CONSOLE(11)] "A preload for 'https://www.nfl.com/compiledassets/css/base.css?_t=450963c95b349de85517a5b17227f17e' is found, but is not used because the request credentials mode does not match. Consider taking a look at crossorigin attribute.", source: https://www.nfl.com/activate/done/29GK5M (11)
[0513/082558.789:INFO:CONSOLE(11)] "A preload for 'https://www.nfl.com/compiledassets/theming/936e9c4e6b4be40493ce5b361703787b' is found, but is not used because the request credentials mode does not match. Consider taking a look at crossorigin attribute.", source: https://www.nfl.com/activate/done/29GK5M (11)
[0513/082601.618:INFO:CONSOLE(3)] "fired plugins", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (3)
[0513/082602.687:INFO:CONSOLE(15)] "🚀 container.buildInfo.environment is deprecated.Please use `container.environment.stage` instead", source: https://assets.adobedtm.com/a5ea4e8f4344/1648c62d3986/launch-53368d199d70.min.js (15)
As a comparison, here is Science Channel being rescanned:
DevTools listening on ws://127.0.0.1:56522/devtools/browser/7b27b58d-bf6c-48d7-b995-046aa77b278d
[0513/084105.494:INFO:CONSOLE(107)] "SentryLogger init", source: https://auth.sciencechannel.com/vendors~main.e2492acf456edbedc7f2.bundle.js (107)
[0513/084109.493:INFO:CONSOLE(349)] "autoStart is true", source: https://auth.sciencechannel.com/vendors~main.e2492acf456edbedc7f2.bundle.js (349)
[0513/084116.691:INFO:CONSOLE(349)] "tvejs scienceSelect: path=/login-affiliates", source: https://auth.sciencechannel.com/vendors~main.e2492acf456edbedc7f2.bundle.js (349)
[0513/084118.308:INFO:CONSOLE(349)] "redirecting to "https://api.auth.adobe.com/api/v1/authenticate?reg_code=LTZKYY8&domain_name=discovery.com&mso_id=Cox&noflash=true&requestor_id=discovery&redirect_url=https%3A%2F%2Fus1-prod.disco-api.com%2Fv1%2Fgauth%2Fcallback%2F5ad3505e-faa7-4b6d-ad8b-ffc1b8c7a396"", source: https://auth.sciencechannel.com/vendors~main.e2492acf456edbedc7f2.bundle.js (349)
[0513/084121.693:INFO:CONSOLE(406)] "onSuccessUrl https://login.cox.com/app/ccires_tveverywhere_1/exk1jha9awwp564kZ0h8/sso/saml?SAMLRequest=hVPbctowEH3vV3j07gvmUtCAMzQ0U2bS1AWnD3nJCHnBIrbkamUuf1%2FZgEubNH3Uavecs3t2xzeHInd2oFEoOSEdLyAOSK5SITcT8pjcuUNyE30YIyvysKTTymRyAT8rQONMEUEbW3erJFYF6CXoneDwuLifkMyYEqnvY%2BkxW%2BSxVK3A46qwEb9G85fTr%2FevIIgzs9BCMtPouaDkaiOkrT40CKwsfc6FBnw2O7Dij%2FsMNDx3fDi8dLYZG7H9vuwPei9PQTb0EVXDSJw7pTk0PUzImuUIxJnPJoT1e8NNtkm7sBqNBjwNQ0h722EwSrt8%2B7FvkzBmiGIHv8sQK5hLNEyaCQmDMHSDvtvpJp2Q9jo0DLxw0HsiTqyVUVzln4Q8jbTSkiqGAqlkBSA1nNaDoKEX0NUpCemXJInd%2BNsyIc6PizVhbY01SyI9mfE%2BVnkmJtHJO9oo1tcI7wOwizUkar20Vd4rQ8f%2BNUF0WZXPBwOylo7R2GS6NEe6ACyVTBN1VnEK%2F1vGpQcKB2OThU7dkmlz%2FL%2Bivwmjs8g%2FZZ1DD5Z0PotVLvjRmea52t9qYMaabXQFzdYUzLw%2FrToiUnfdpFKjmeUAaYizjGv47xXLxVqAvjqMN6X7SroryFi%2BdtXaTwVyVe838Vu1S65KuyTt%2B3yNoOezqM1v273%2BbYMthP%2FGWUe%2FAA%3D%3D&RelayState=766c5ddc-272e-478c-9091-be978b43b492&SigAlg=http%3A%2F%2Fwww.w3.org%2F2000%2F09%2Fxmldsig%23rsa-sha1&Signature=tHp6fuAF21NZohYtvD1d54zwjyAlFLwJstAx30GDP3tF2CAYFggihPWSFegs0z1EaypbsN6%2BKKM0f4M%2BJEO2feJslpPcICkZxAZYnqcLi%2BG5AYuQZfSkjsajeHBw%2BAlon7KxypltzPZULrtvZklBzKGkFhCCMnpQSKIKPlQJ72ryNKjnKimTd8d3R1M4oKxLnLfVmAjMFZfzZ0Y9YAyRVO55eSIDPzfs5AHZ2e%2Be5ABdszdv2cZp3%2FiZ52SmvjDQsv7rjWMqxR4w5%2F9shiUs7pZ%2BwPmCK0y3BgcrF34PLezYdd7av5tW3sH8A%2BsIpYoYGh7UYPd%2F3iCn3t9VvQ6Frw%3D%3D", source: https://www.cox.com/content/dam/cox/okta/loginwidget.html?fromURI=https%3A%2F%2Flogin.cox.com%2Fapp%2Fccires_tveverywhere_1%2Fexk1jha9awwp564kZ0h8%2Fsso%2Fsaml%3FSAMLRequest%3DhVPbctowEH3vV3j07gvmUtCAMzQ0U2bS1AWnD3nJCHnBIrbkamUuf1%252FZgEubNH3Uavecs3t2xzeHInd2oFEoOSEdLyAOSK5SITcT8pjcuUNyE30YIyvysKTTymRyAT8rQONMEUEbW3erJFYF6CXoneDwuLifkMyYEqnvY%252BkxW%252BSxVK3A46qwEb9G85fTr%252FevIIgzs9BCMtPouaDkaiOkrT40CKwsfc6FBnw2O7Dij%252FsMNDx3fDi8dLYZG7H9vuwPei9PQTb0EVXDSJw7pTk0PUzImuUIxJnPJoT1e8NNtkm7sBqNBjwNQ0h722EwSrt8%252B7FvkzBmiGIHv8sQK5hLNEyaCQmDMHSDvtvpJp2Q9jo0DLxw0HsiTqyVUVzln4Q8jbTSkiqGAqlkBSA1nNaDoKEX0NUpCemXJInd%252BNsyIc6PizVhbY01SyI9mfE%252BVnkmJtHJO9oo1tcI7wOwizUkar20Vd4rQ8f%252BNUF0WZXPBwOylo7R2GS6NEe6ACyVTBN1VnEK%252F1vGpQcKB2OThU7dkmlz%252FL%252Bivwmjs8g%252FZZ1DD5Z0PotVLvjRmea52t9qYMaabXQFzdYUzLw%252FrToiUnfdpFKjmeUAaYizjGv47xXLxVqAvjqMN6X7SroryFi%252BdtXaTwVyVe838Vu1S65KuyTt%252B3yNoOezqM1v273%252BbYMthP%252FGWUe%252FAA%253D%253D%26RelayState%3D766c5ddc-272e-478c-9091-be978b43b492%26SigAlg%3Dhttp%253A%252F%252Fwww.w3.org%252F2000%252F09%252Fxmldsig%2523rsa-sha1%26Signature%3DtHp6fuAF21NZohYtvD1d54zwjyAlFLwJstAx30GDP3tF2CAYFggihPWSFegs0z1EaypbsN6%252BKKM0f4M%252BJEO2feJslpPcICkZxAZYnqcLi%252BG5AYuQZfSkjsajeHBw%252BAlon7KxypltzPZULrtvZklBzKGkFhCCMnpQSKIKPlQJ72ryNKjnKimTd8d3R1M4oKxLnLfVmAjMFZfzZ0Y9YAyRVO55eSIDPzfs5AHZ2e%252Be5ABdszdv2cZp3%252FiZ52SmvjDQsv7rjWMqxR4w5%252F9shiUs7pZ%252BwPmCK0y3BgcrF34PLezYdd7av5tW3sH8A%252BsIpYoYGh7UYPd%252F3iCn3t9VvQ6Frw%253D%253D&partner=discovery (406)
[0513/084127.291:INFO:CONSOLE(417)] "Uncaught TypeError: coxLogin.updateRememberMeCookie is not a function", source: https://www.cox.com/content/dam/cox/okta/loginwidget.html?fromURI=https%3A%2F%2Flogin.cox.com%2Fapp%2Fccires_tveverywhere_1%2Fexk1jha9awwp564kZ0h8%2Fsso%2Fsaml%3FSAMLRequest%3DhVPbctowEH3vV3j07gvmUtCAMzQ0U2bS1AWnD3nJCHnBIrbkamUuf1%252FZgEubNH3Uavecs3t2xzeHInd2oFEoOSEdLyAOSK5SITcT8pjcuUNyE30YIyvysKTTymRyAT8rQONMEUEbW3erJFYF6CXoneDwuLifkMyYEqnvY%252BkxW%252BSxVK3A46qwEb9G85fTr%252FevIIgzs9BCMtPouaDkaiOkrT40CKwsfc6FBnw2O7Dij%252FsMNDx3fDi8dLYZG7H9vuwPei9PQTb0EVXDSJw7pTk0PUzImuUIxJnPJoT1e8NNtkm7sBqNBjwNQ0h722EwSrt8%252B7FvkzBmiGIHv8sQK5hLNEyaCQmDMHSDvtvpJp2Q9jo0DLxw0HsiTqyVUVzln4Q8jbTSkiqGAqlkBSA1nNaDoKEX0NUpCemXJInd%252BNsyIc6PizVhbY01SyI9mfE%252BVnkmJtHJO9oo1tcI7wOwizUkar20Vd4rQ8f%252BNUF0WZXPBwOylo7R2GS6NEe6ACyVTBN1VnEK%252F1vGpQcKB2OThU7dkmlz%252FL%252Bivwmjs8g%252FZZ1DD5Z0PotVLvjRmea52t9qYMaabXQFzdYUzLw%252FrToiUnfdpFKjmeUAaYizjGv47xXLxVqAvjqMN6X7SroryFi%252BdtXaTwVyVe838Vu1S65KuyTt%252B3yNoOezqM1v273%252BbYMthP%252FGWUe%252FAA%253D%253D%26RelayState%3D766c5ddc-272e-478c-9091-be978b43b492%26SigAlg%3Dhttp%253A%252F%252Fwww.w3.org%252F2000%252F09%252Fxmldsig%2523rsa-sha1%26Signature%3DtHp6fuAF21NZohYtvD1d54zwjyAlFLwJstAx30GDP3tF2CAYFggihPWSFegs0z1EaypbsN6%252BKKM0f4M%252BJEO2feJslpPcICkZxAZYnqcLi%252BG5AYuQZfSkjsajeHBw%252BAlon7KxypltzPZULrtvZklBzKGkFhCCMnpQSKIKPlQJ72ryNKjnKimTd8d3R1M4oKxLnLfVmAjMFZfzZ0Y9YAyRVO55eSIDPzfs5AHZ2e%252Be5ABdszdv2cZp3%252FiZ52SmvjDQsv7rjWMqxR4w5%252F9shiUs7pZ%252BwPmCK0y3BgcrF34PLezYdd7av5tW3sH8A%252BsIpYoYGh7UYPd%252F3iCn3t9VvQ6Frw%253D%253D&partner=discovery (417)
[0513/084127.906:INFO:CONSOLE(541)] "[object Object]", source: https://www.cox.com/content/dam/cox/okta/loginwidget.html?fromURI=https%3A%2F%2Flogin.cox.com%2Fapp%2Fccires_tveverywhere_1%2Fexk1jha9awwp564kZ0h8%2Fsso%2Fsaml%3FSAMLRequest%3DhVPbctowEH3vV3j07gvmUtCAMzQ0U2bS1AWnD3nJCHnBIrbkamUuf1%252FZgEubNH3Uavecs3t2xzeHInd2oFEoOSEdLyAOSK5SITcT8pjcuUNyE30YIyvysKTTymRyAT8rQONMEUEbW3erJFYF6CXoneDwuLifkMyYEqnvY%252BkxW%252BSxVK3A46qwEb9G85fTr%252FevIIgzs9BCMtPouaDkaiOkrT40CKwsfc6FBnw2O7Dij%252FsMNDx3fDi8dLYZG7H9vuwPei9PQTb0EVXDSJw7pTk0PUzImuUIxJnPJoT1e8NNtkm7sBqNBjwNQ0h722EwSrt8%252B7FvkzBmiGIHv8sQK5hLNEyaCQmDMHSDvtvpJp2Q9jo0DLxw0HsiTqyVUVzln4Q8jbTSkiqGAqlkBSA1nNaDoKEX0NUpCemXJInd%252BNsyIc6PizVhbY01SyI9mfE%252BVnkmJtHJO9oo1tcI7wOwizUkar20Vd4rQ8f%252BNUF0WZXPBwOylo7R2GS6NEe6ACyVTBN1VnEK%252F1vGpQcKB2OThU7dkmlz%252FL%252Bivwmjs8g%252FZZ1DD5Z0PotVLvjRmea52t9qYMaabXQFzdYUzLw%252FrToiUnfdpFKjmeUAaYizjGv47xXLxVqAvjqMN6X7SroryFi%252BdtXaTwVyVe838Vu1S65KuyTt%252B3yNoOezqM1v273%252BbYMthP%252FGWUe%252FAA%253D%253D%26RelayState%3D766c5ddc-272e-478c-9091-be978b43b492%26SigAlg%3Dhttp%253A%252F%252Fwww.w3.org%252F2000%252F09%252Fxmldsig%2523rsa-sha1%26Signature%3DtHp6fuAF21NZohYtvD1d54zwjyAlFLwJstAx30GDP3tF2CAYFggihPWSFegs0z1EaypbsN6%252BKKM0f4M%252BJEO2feJslpPcICkZxAZYnqcLi%252BG5AYuQZfSkjsajeHBw%252BAlon7KxypltzPZULrtvZklBzKGkFhCCMnpQSKIKPlQJ72ryNKjnKimTd8d3R1M4oKxLnLfVmAjMFZfzZ0Y9YAyRVO55eSIDPzfs5AHZ2e%252Be5ABdszdv2cZp3%252FiZ52SmvjDQsv7rjWMqxR4w5%252F9shiUs7pZ%252BwPmCK0y3BgcrF34PLezYdd7av5tW3sH8A%252BsIpYoYGh7UYPd%252F3iCn3t9VvQ6Frw%253D%253D&partner=discovery (541)
[0513/084127.907:INFO:CONSOLE(543)] "User %s successfully authenticated %o {REDACTED} [object Object]", source: https://www.cox.com/content/dam/cox/okta/loginwidget.html?fromURI=https%3A%2F%2Flogin.cox.com%2Fapp%2Fccires_tveverywhere_1%2Fexk1jha9awwp564kZ0h8%2Fsso%2Fsaml%3FSAMLRequest%3DhVPbctowEH3vV3j07gvmUtCAMzQ0U2bS1AWnD3nJCHnBIrbkamUuf1%252FZgEubNH3Uavecs3t2xzeHInd2oFEoOSEdLyAOSK5SITcT8pjcuUNyE30YIyvysKTTymRyAT8rQONMEUEbW3erJFYF6CXoneDwuLifkMyYEqnvY%252BkxW%252BSxVK3A46qwEb9G85fTr%252FevIIgzs9BCMtPouaDkaiOkrT40CKwsfc6FBnw2O7Dij%252FsMNDx3fDi8dLYZG7H9vuwPei9PQTb0EVXDSJw7pTk0PUzImuUIxJnPJoT1e8NNtkm7sBqNBjwNQ0h722EwSrt8%252B7FvkzBmiGIHv8sQK5hLNEyaCQmDMHSDvtvpJp2Q9jo0DLxw0HsiTqyVUVzln4Q8jbTSkiqGAqlkBSA1nNaDoKEX0NUpCemXJInd%252BNsyIc6PizVhbY01SyI9mfE%252BVnkmJtHJO9oo1tcI7wOwizUkar20Vd4rQ8f%252BNUF0WZXPBwOylo7R2GS6NEe6ACyVTBN1VnEK%252F1vGpQcKB2OThU7dkmlz%252FL%252Bivwmjs8g%252FZZ1DD5Z0PotVLvjRmea52t9qYMaabXQFzdYUzLw%252FrToiUnfdpFKjmeUAaYizjGv47xXLxVqAvjqMN6X7SroryFi%252BdtXaTwVyVe838Vu1S65KuyTt%252B3yNoOezqM1v273%252BbYMthP%252FGWUe%252FAA%253D%253D%26RelayState%3D766c5ddc-272e-478c-9091-be978b43b492%26SigAlg%3Dhttp%253A%252F%252Fwww.w3.org%252F2000%252F09%252Fxmldsig%2523rsa-sha1%26Signature%3DtHp6fuAF21NZohYtvD1d54zwjyAlFLwJstAx30GDP3tF2CAYFggihPWSFegs0z1EaypbsN6%252BKKM0f4M%252BJEO2feJslpPcICkZxAZYnqcLi%252BG5AYuQZfSkjsajeHBw%252BAlon7KxypltzPZULrtvZklBzKGkFhCCMnpQSKIKPlQJ72ryNKjnKimTd8d3R1M4oKxLnLfVmAjMFZfzZ0Y9YAyRVO55eSIDPzfs5AHZ2e%252Be5ABdszdv2cZp3%252FiZ52SmvjDQsv7rjWMqxR4w5%252F9shiUs7pZ%252BwPmCK0y3BgcrF34PLezYdd7av5tW3sH8A%252BsIpYoYGh7UYPd%252F3iCn3t9VvQ6Frw%253D%253D&partner=discovery (543)
[0513/084129.450:INFO:CONSOLE(107)] "SentryLogger init", source: https://auth.sciencechannel.com/vendors~main.e2492acf456edbedc7f2.bundle.js (107)
[0513/084129.638:INFO:CONSOLE(349)] "autoStart is true", source: https://auth.sciencechannel.com/vendors~main.e2492acf456edbedc7f2.bundle.js (349)
[0513/084130.451:INFO:CONSOLE(349)] "data: [{"attributes":{"lastLoginTime":"2022-04-21T12:19:34Z","realm":"go","token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJzdWIiOiJVU0VSSUQ6Z286YTllZWM2OTgtOTM4ZC00MzQ4LWE5MGQtNDY5M2Y0MGQ3MjNjIiwianRpIjoidG9rZW4tMTE5NGE5NjYtMjVkOC00ZjQyLTg4OTUtYTQ1ODM0MTA5MmU5IiwiYW5vbnltb3VzIjpmYWxzZSwiaWF0IjoxNjUyNDQ1NjkxfQ.vGPyWWraOxqTCJnpj48WXXUVtVsF5dwzSk5JhwkNxCg"},"id":"token-1194a966-25d8-4f42-8895-a458341092e9","type":"token"}]", source: https://auth.sciencechannel.com/vendors~main.e2492acf456edbedc7f2.bundle.js (349)
So with the NFL Network, Channels successfully logs into the TVE provider, which is why it is coming back with the checkmark. However, the station does not connect because the container is depreciated and has been replaced by another one. @tmm1, @maddox, @eric, it looks like a fix is needed for this.
They must be busy putting out bigger fires. Its unusual to not see a response by now.
I'm have the same issue . I get no Login found. The NFL Network apps work but wont load in channels. Seems to happen every few months
I now have had a complete server reboot to no effect.
[ERR] Failed to start stream for ch6192: TVE: Could not parse playlist: dcs-live.mp.lura.live: Can't detect playlist type
I am also having this issue. (Spectrum) I can watch via browser, but not in Channels
I'm amazed that this hasn't been addressed by the Channels Devs yet.
Fixed in latest pre-release
I updated this morning, still with no joy, were there two updates available today?
Im on 2022.05.16.1458, still getting the same error.
just fixed in v2022.05.16.1751 - later than the one from this morning.
Can confirm this is working for me. Didn't even need to rescan!
I am still getting context cancelled when I rescan.
My error on the NFL channel is: playback failed could not parse playlist: dcs-live.msp.lura.live: can’t detect playlist type. Server 2022.05.16.2100 and Nvidia client current alpha 203.18.101 am I have a different issue than others?
On .2100 I get "no login form found".
