NFL RedZone
Stream is now active on redesigned AppleTV app so the TVE version should be online as well.
New build is uploading now. It will be ready in about 10-15 minutes. I tested on SlingTV and it works.
Awesome! Thanks for the great customer support!
I updated to Version 2019.09.15.0041, but still getting neu: 400 Bad Request.
I have Sling TV as well
That isnt the one that we are waiting on i believe, i think that one was from last night. should be any minute now.
Sorry the previous upload failed. Another one is going now.
Not a worry, thanks for checking on this.
I still don't see the new update.
Build v2019.09.15.1811 is up now
It's working great, thanks again!
Working with Optimum. Great work! THANKS!
Where do I download the build?
Press and hold down Check for Updates and it will download
Works with Dish. Thanks!
Not authorizing with Vue, but seems like a Vue issue as I can't get it to work with the NFL app either.
I can confirm it is working with Spectrum also. Thank you, great job as always from Channels from a customer service perspective!
If HDHomeRun would just get the 6 tuner PRIME out and available I could kick TiVo to the curb permanently.
Is there any ETA for 6 tuner prime ?
Coming 2019 (last year it was coming 2018).
Redzone working great. Thank you!
Ahhh nuts. I got so stoked until I realized RedZone isn't supported with an Xfinity login. :frowning: Love the quick updates and support here though!
Side note, working with FuboTV credentials!
