Non-Docker source for PlutoTV m3u playlists and EPG
I just want to say thank you for doing this. I am running my DVR on a Raspberry Pi and thanks to you I can integrate Pluto and Stirr. Donated to support you. Great work.
Hi everyone-- was traveling a bit.. thanks for the comments and you're welcome! And thanks for the support @realimpact4g
I coming to this late in the day and I haven't read the entire thread so I may have missed something, but I don't like grabbing someone else's CPU and bandwidth.
Would it be possible to add editable tokens for time so Channels could do something like "http://api.pluto.tv/v2/channels?start=${startTime}&stop=${stopTime}" in the guide data field ? That way we can pull direct and Hank doesn't get me beating up on his servers every few hours.
I'm not really sure what you mean. Channels cannot ingest the json from pluto directly, that's why the docker exists to convert it into XMLTV. The version here is simply a docker that someone else is hosting. If you don't want to use that, you can host or run the docker yourself.
There's actually nothing to worry about here (but thanks for the thought).. all the nocords.xyz files are edge-cached with Cloudflare and the edge cache refreshes from my server every 30 minutes (or 3 hours) depending on the file. So hit those links as hard as you want, it doesn't really affect my server.
(this was covered previously in this thread -- you must have missed those posts. :wink: )
Thanks. I won't worry then. Cloudflare can definitely afford it. Appreciate the community work !
Just start using Channels (fantastic) and found this thread about Pluto and Stirr.
Thank you for making the Pluto/Stirr services available without Docker..
One suggestion, you may want to update your first post to reflect the custom channel # start option.
Only wanted to stop by this thread to say thank you very much for making the Pluto/Stirr services available so easily. I was able to get both up and running on my Synology DS920+ in less than 5 minutes.
Using the custom channel URL is exceptionally handy for Pluto, otherwise a few of the default channel numbers conflict with Freeview UK (101 for example) - not to mention they were mixed in amongst the Freeview UK channels and it looked a bit messy in the guide. I prefer to have my Freeview channels listed first / as primary in the guide - then Pluto, then Stirr after that. The custom channel URL allows me to do this and the layout is much friendlier to look at as a result. I used a custom URL for Pluto to start at 5000, and it works great. Stirr starts at 9000 by default with no need for the custom string. No conflicts and so far so good.
Thank you!
Thanks for your comments! And you're welcome.
I started this more as a "I wonder if I can figure this out?" project. And when it worked, I realized it could be pretty useful to everyone else using the Docker module.
This works great....nice to have some additional channels to choose from.
For sure, it's very useful to Docker users, and actually for me it was the opposite - I've only just got my DS920+ set up and as such I'm not that well versed in Docker yet. This saved me a bunch of time as I don't need to set up containers for these now, and it all just worked immediately. Thanks again!
I've been using the non-docker source for pluto for 6 months now with absolutely no issues. Very grateful for an easy way to add pluto without docker. With that said is there something I need to do on my server to update the EPG or M3U to pick up recently changed or added channels? Specifically, my list of available channels does not list Jeopardy or Wheel of Fortune even though they are available on Pluto.tv. I've refreshed the M3U and EPG but that did not make the channels appear.
See:
Hello everyone!
I just wanted to say that I can't believe it's been an entire year since I started this thread! Seems like just yesterday we ditched Cablevision/Optimum cable (NO CORDS!) for fiber internet service and Channels DVR (ok, maybe one cord). Looks like Channels DVR is here to stay in our home. :wink:
Just as an FYI....here are the recent changes I picked up (subtract 10000 from the channel number to get the Pluto channel) It also picks up when they change the channel name.
10/10/22 10:15 Channel add detected: The Walking Dead Universe channel (10227)
10/10/22 10:15 Channel add detected: CSI: Miami en Español channel (12761)
10/10/22 10:15 Channel add detected: CSI: NY en Español channel (12762)
10/10/22 10:15 Total changes detected: 3 added, 0 deleted
10/03/22 10:15 Channel add detected: Cheaters channel (10837)
10/03/22 10:15 Channel add detected: CBS News Philadelphia channel (13395)
10/03/22 10:15 Channel delete detected: CBS News Philly channel (13395)
10/03/22 10:15 Total changes detected: 2 added, 1 deleted
09/27/22 10:15 Channel add detected: CNN RePlay channel (10415)
09/27/22 10:15 Channel delete detected: CNN channel (10415)
09/27/22 10:15 Total changes detected: 1 added, 1 deleted
09/26/22 12:15 Channel add detected: Hallmark Movies & More channel (10258)
09/26/22 12:15 Channel add detected: The Rachael Ray Show channel (11093)
09/26/22 12:15 Total changes detected: 2 added, 0 deleted
Hi all,
I have had Pluto and Stirr added via this excellent method for a short while now, and everything works great. However, I noticed recently (maybe a couple of weeks back but could have occurred before), that the channel images for Stirr no longer show.
This is reflected in the guide on the Apple TV GUI.
Pluto TV is fine.
Anyone else seeing this? Settings look fine. I haven't tried removing and re-adding the source yet as wanted to check in here first.
Just further to the above, if I look at the EPG XML from https://nocords.xyz/stirr/epg.xml and try to copy and paste some of the icon URLs into a browser, for example this one:
I get this error:
403 ERROR
The request could not be satisfied.
The Amazon CloudFront distribution is configured to block access from your country. We can't connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner.
If you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation.
Accessing the URL from a UK IP (Virgin Media).
Access to the channels is still working great though.
Thanks
That looks like an issue with the source images from Stirr.. but I'm traveling for the week and I can investigate further when I get back next week.
Can you try using the "custom" link for Stirr and see if the images are available?
I just tried changing it to
https://nocords.xyz/stirr/custom.php?start=10000
The update to the channel numbers is immediately reflected in the guide / line-up, but the images still do not load.
So it seems to behave the same whether I use the custom link or the straight m3u one.
Thank you!
What is curious though is if I download the custom m3u file, I can see the source for the image logos is from nocords.xyz rather than that other URL I posted above. If I manually copy and paste one of the nocords.xyz links into a browser, the logo loads.
Anyhow, in the channels backend, if I go to 'manage line-up' and inspect the broken images using the browser, the source for these is still looking to gateway.sinclairstoryline.com which is what seems to no longer be accessible.
I think it must be looking at epg.xml as this file is the one that references gateway.sinclairstoryline.com.
I'm not sure, just putting my findings out there. Probably not explaining them very well!
