Didn’t respond since this was a non-docker thread but could add Sweden if that is wanted within a docker version
I had created a m3u channel in my DVR. As of a few days ago I can no longer see the channels listed in my guide. Have the parameters changed recently.
I am trying to attach a screenshot of my Source settings for Pluto.
Thanks
You're using the non-Docker source, "nocords.xyz" URL, created by @HankLloydRight.
It might be better to post your question in the dedicated thread for that method:
Looks like you’re using a VPN. Please try turning it off.
hello, i'm getting the same error when trying to use the m3u link (access forbidden, and a cloudfare error. i can't even enter the nocords website). i don't use any vpn. is it based on location ? because i don't live in western country
could you help me out ? thanks in advance !
It could be based on Country. Next time you get the Cloudflare error page, please post the "RAY ID" at the bottom and I can investigate.
here it is : 8f48a8282a9ab79e
Yes, your country is being blocked due to increased hacking attacks. Sorry.
coming from my country ? i hate people so bad lol. thanks for the help tho !
My apologies -- I meant from your continent.
Personally I'm using this docker for Pluto now (easy enough to install via OliveTin's "Project One-Click" section) - but, as an alternative, here's another non-Docker source for Pluto:
While they recommend rolling your own for long-term use, there is a publicly accessible URL you'd use in your country:
https://tinyurl.com/multiservice21?region=ADD_REGION&service=pluto
Available Region Parameter Values
all (for all regions)
ar (Argentina)
br (Brazil)
ca (Canada)
cl (Chile)
de (Germany)
dk (Denmark)
es (Spain)
fr (France)
gb (United Kingdom)
mx (Mexico)
no (Norway)
se (Sweden)
us (United States)
as well as instructions for how to run it as your own Google Web app, or via docker:
I've been playing around with it and it works fine. Only Roku's down right now: Issues · dtankdempse/free-iptv-channels · GitHub
it worked, thank you so much !!
Can you add UK and Canada channels?
Thanks
This repo is forked from the maddox repo. If he can update his source repo for that, than I can follow.
@HankLloydRight ... Cloudflare blocking of nocords.xyz from VPNs (Windscribe, Torguard) seems to have been activated recently. Can this be undone or do I need to go back to using a docker?
It's not recent -- it's been this way since the site launched. It's to prevent common hacking attacks from countries and questionable datacenters that are used for nefarious VPNs. I'm sorry to say that it won't change.
Change DNS providers. Open DNS provides security without the denial of service.
I'm not sure how changing DNS providers would change the originating IP address of the client or VPN node.
I did not notice the VPN. Is there a reason he needs to tunnel to nocords.zyz? He could make an exception if he understands VPN routing.
